brake control not working
Old Jun 22, 2010 | 10:26 PM
bakerbuilttracks's Avatar
bakerbuilttracks
i got a late 99 f250 7.3. i have an actavator brake controller in my truck. when i press the brake pedal the little red light comes on with or with out the trailer hooked up. recently driving arround i have noticed the light is not comming on. i hooked up the trailer and the actavator is not working. any suggestions
Old Jun 22, 2010 | 11:20 PM
Steina's Avatar
Steina
CO River Rat
Sounds like you've got no power to the controller (no red light) - check for a blown fuse.
Steve
Old Jun 25, 2010 | 10:54 AM
TexasRebel's Avatar
TexasRebel
is your center brake light coming on?
Old Jun 25, 2010 | 03:36 PM
bakerbuilttracks
Steve
Steve where should i look for a fuse.... on the controller or in 1 of the 2 fuse boxes. i dont think the controller has an inline fuse
Old Jun 25, 2010 | 03:37 PM
bakerbuilttracks
i will look and see if the center light is comming on. what would that have todo with anything im curious
Old Jun 25, 2010 | 05:32 PM
TexasRebel's Avatar
TexasRebel
brake controllers normally get their signal to activate from the CHMSL circuit. If the fuse is blown your brake controller won't get a signal, nor will the lamp come on.
Old Jun 25, 2010 | 08:02 PM
bakerbuilttracks
ummm makes sense i will check it and post back. if its a fuse where will it be?
Old Jun 25, 2010 | 08:35 PM
cdrmotorsports's Avatar
cdrmotorsports
The fuse will be in either of the two fuse boxes, I can't really remember which one but I'm pretty sure on the '99 it's the fuse box located under the steering wheel. You manual will tell you exactly which one it is.
Old Jun 25, 2010 | 09:09 PM
bakerbuilttracks
10.4 thanks i will check all tomm and post back
cabloom300
15
Feb 21, 2012 08:35 AM
Trophy_23
Aug 24, 2011 09:35 PM
snu1910
6.4L Power Stroke Diesel
15
Dec 20, 2010 09:12 AM
donk
Feb 20, 2002 09:29 AM
