6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
please help
Old Dec 19, 2010 | 06:01 PM
snu1910's Avatar
snu1910
please help
i have a 2008 F350. i had the edge CTS chip in it. i took the chip out to update it. it told me that i needed to rest the truck to stock. i reinstall the chip and set back to stock. hook chip back up to update and it still says its not stock and the truck and actavated the anti-theft light on the dash and i will not let me start to truck. please help.
Old Dec 19, 2010 | 06:36 PM
Thenewboss's Avatar
Thenewboss
I spent a little time tuning my last car (Subaru). I know it's apples to oranges, but try reseting the trucks computer by disconnecting the battery and stepping on the brake pedal to discharge the system. This SHOULD bring you back to the stock baseline.
Old Dec 19, 2010 | 06:42 PM
snu1910's Avatar
snu1910
thank you i will go try it right now. i will let u know what happens
Old Dec 19, 2010 | 07:09 PM
snu1910's Avatar
snu1910
that did not work. still stuck with the anti theft light flashing.
Old Dec 19, 2010 | 07:18 PM
Thenewboss's Avatar
Thenewboss
Ok, worth a shot. Does your anti-theft system have a "Valet" mode that it may have slipped into? Maybe a fuse to disable it?
Old Dec 19, 2010 | 07:22 PM
snu1910's Avatar
snu1910
checked all the fuses that i can find and didnt see any that that looked bad.
Old Dec 19, 2010 | 07:56 PM
Thenewboss's Avatar
Thenewboss
The only thing I got left is check your owners manual for a way to reset your security system, like putting the key in the ignition and turning it 3 times for example. Just a couple shots in the dark for you, maybe someone that knows something will chime in. Good luck.
Old Dec 19, 2010 | 07:58 PM
snu1910's Avatar
snu1910
Thumbs down
look for that information and thats how i found this form. im thinking it just going to have to go to the doctor to get looked at tom morning.
Old Dec 19, 2010 | 08:03 PM
powerstroke72's Avatar
powerstroke72
Sorry but you didn't post it up yet....I'm assuming this is a 6.4 Diesel?
Old Dec 19, 2010 | 08:05 PM
snu1910's Avatar
snu1910
yes sorry. i for got to add that part.
Old Dec 19, 2010 | 08:46 PM
powerstroke72
No problem. Oh and by the way, Welcome to FTE! I'm going to move your thread to the 6.4 Diesel forum where you will probably get a little more response.
Thread moved to 6.4 Powerstroke Diesel forum.
Old Dec 19, 2010 | 08:47 PM
snu1910's Avatar
snu1910
thank u very much for that. im have been one of the people lurking in the dark reading alots and never had any thing to posy
Old Dec 19, 2010 | 09:26 PM
RM2738's Avatar
RM2738
Yeah.... These 6.4's don't quite respond the same as a lot of other vehicles.
When you hook up the edge now, it's still saying your truck is not set to stock?
May give a little more details. Step by step if you can.
Old Dec 19, 2010 | 09:38 PM
snu1910's Avatar
snu1910
i took the chip out this morning to update it. hooked it up to my computer. the software told me that i need to set the truck back to stock. took the chip back out and reconnected it. switched it to stock. brought the chip back to the computer and it still said it was not set to stock. took the chip back out and hooked it back up. wait for it to load and it said i needed to turn the key to the on and not start it. did that then said to turn it off. did that then turn the key back on. when i did the last step it was telling that there is comm error and i need to unplug the chip from the truck. i did this and the anti theft light started flashing. the chip went threw the steps again and the anti theft like just keep flashing.
i tried to disconnect the battery and reset every thing but that did not work. i have checked all the fuses and they all looked fine.
Old Dec 20, 2010 | 05:25 AM
senix's Avatar
senix
I am afraid you have corrupted the pcm. I would think you need a new one. Don't quote me on that.
I seem to recall some others that have run into this and that was the only way to solve the problem. May or may not apply.
I would get the chip people on the phone and have them walk you thru the steps and trouble shoot it.
