Bronco II Ford Bronco II
Water Pump
Old Jun 22, 2010 | 01:21 PM
fordtrucksj's Avatar
fordtrucksj
Water Pump
Hello everyone! I have a question for everyone. I have an 89 B2, 4X4, Manual transmission (FM146).
I installed a new water pump and torqued the bolts according to specs and the pump is leaking around 3 separate bolts. Anyhow, the gasket that came with the new pump is a piece and I should have just trusted my instinct on this one before installing the pump, but I didn't. Anyhow, is there a gasket out there that you might reccomend or do you think it might be OK to use a silicone instead (blue, orange, or black)? I am going to take it apart again, but hope this is the last time for a LONG time. Thanks everyone.
Old Jun 23, 2010 | 02:56 AM
rebocardo's Avatar
rebocardo
They make one just for anti-freeze. Put a skim coat on the pump and on the block and into the bolt holes and then right under the bolt head (comes in a little tube) before you torque it down. You have to use good n tight without breaking the bolts (major hassle).
I might put some anti-seize with a Q-tip inside the threads on the block, BUT, I can't remember if it is this engine or the Chr. 318 that requires RTV on the bolt threads so it does not leak.
Old Jun 24, 2010 | 10:28 AM
fordtrucksj
I might put some anti-seize with a Q-tip inside the threads on the block, BUT, I can't remember if it is this engine or the Chr. 318 that requires RTV on the bolt threads so it does not leak.[/quote]
What do you mean by "use good n tight without breaking the bolts." Is "good n tight" a type of chemical or RTV (like "lock tight" or did you mean that I have to put the bolts back in good n tight as in how I torque them down? Also, I want to make sure that I was clear in my original post, I plan on NOT using the paper thin (looks thinner than cereal box card board) gasket and instead using ONLY silicone/RTV...you feel this would be OK (and of course, RTV on the bolt threads like you suggest). Thank you Robocardo!
Supercab
25
Oct 6, 2012 01:14 PM
Hank85713
1983 - 2012 Ranger & B-Series
Aug 17, 2012 12:17 AM
Zephyrhills Ford
Oct 7, 2010 03:28 PM
gsxr-freak
15
May 4, 2009 10:25 AM
53Merc
Jul 10, 2005 11:31 PM
