Bronco II Ford Bronco II
no spark
Old Jun 7, 2010 | 06:22 PM
bronco2fan's Avatar
bronco2fan
no spark
I have a newly rebuilt 2.9 in my 88 bronco 2 and i cant get any spark.
screwdriver stuck in a plug wire gives a reddish colored spark against a ground but when i try with a plug i get no spark.
i bench tested the coil and it falls in spec can the coil be bad and bench test good?
HELP
Old Jun 7, 2010 | 10:11 PM
mrshorty's Avatar
mrshorty
I would probably start by pulling codes and checking the ICM.
Old Jun 8, 2010 | 03:49 AM
rebocardo's Avatar
rebocardo
My first assumption would be the timing is off and the dist. is probably on the exhaust stroke and not the compression, 180 degrees off.
Old Jun 9, 2010 | 07:48 PM
bronco2fan's Avatar
bronco2fan
codes are 22, 122
what do i need to check on the ICM
dist isn't out 180 already checked that before i realized the plugs were not sparking
Old Jun 9, 2010 | 10:16 PM
mrshorty's Avatar
mrshorty
KOEO/CM 22 points to a MAP circuit problem. Doesn't seem like it should be related to a no spark, unless the ICM and MAP wires go through the same harness.
I don't remember the specific steps for testing the ICM, it seems like someone posted them here at one point. Some parts stores will test ICM's in the hopes of selling you a new one.
Old Jun 16, 2010 | 07:06 PM
bronco2fan's Avatar
bronco2fan
had the ICM tested at the parts store. they said it failed at high rpms.
would this keep it from putting enough power to the plugs to start
i am going to replace it
Old Jun 24, 2010 | 08:26 PM
bronco2fan's Avatar
bronco2fan
got it the icm changed out along with the cap and rotor. now i have spark but it has a red color
Gordesky Mco
Aug 10, 2014 04:32 PM
makthenif
1997 - 2003 F150
Apr 24, 2014 08:49 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
nismo_2
1978 - 1996 Big Bronco
Apr 26, 2004 05:17 PM
kvc2
May 7, 2001 09:00 PM
