Sponsored by: Real Truck
Backup Camera
Old Jun 21, 2010 | 04:27 PM
DIXIEDOG1's Avatar
DIXIEDOG1
Backup Camera
Anyone have luck fitting a decent back up camera to their Super Duty that originally didn't come with one? I'd like to have an auto dimming rearview mirror that displayed the back up camera image when the truck shifts into reverse.
Old Jun 21, 2010 | 04:45 PM
Wagion's Avatar
Wagion
Truck Make, Model, Year?
Have you looked at putting in one of the factory ones? Not sure what year they started with those.
There is a shop in my town that mounts the cameras inside the tail gate and cut out a hole in the tailgate to mount it they fab up their own mounts and not sure e how they mount them inside tailgate if they bolt them or weld them or appoxy
Old Jun 21, 2010 | 05:03 PM
DIXIEDOG1's Avatar
DIXIEDOG1
It's a 2010 F250 XLT Super Cab, I emailed Parts Guy Ed and he mentioned he remember seeing where some guys had adapted a mix of factory and aftermarket parts to make a camera work but he wasn't 100% confident on what exactly I would need or the wiring so I though aftermarket might be the way to go. If I had ordered my truck I would have just had the camera added I chose a truck that was on the lot and am adding a camera after the fact.
Old Jun 21, 2010 | 05:47 PM
sdetweil's Avatar
sdetweil
I did the same as this http://f150online.com/forums/other-b...ra-handle.html
I bought the handle(part number 8L3Z 9943400) from online somewhere ($70) the camera from Ebay,
and am installing a head/dvd/cam unit.. in the short term I use the wireless Peak system I found from Sam's Club ($50), and the tailgate camera..
the camera mirror can be found on ebay as well. here is one WITH the camera,.. no wiring..
FORD F150 AUTO DIM REAR MIRROR w/BACKUP CAMERA DISPLAY: eBay Motors (item 140414819188 end time Jul-07-10 16:11:16 PDT)
and this link http://www.thedieselstop.com/forums/...y-unit-244805/ has good info on the camera wiring
AND it MAY be that the wiring is in the headliner for the right mirror..
Sam
Old Jun 22, 2010 | 12:06 AM
rmurray's Avatar
rmurray
I installed a boyo license plate camera. It wired right into my aftermarket head unit. Works great, but some slight interference I think from the motor. It took about an hour to install. Works good at night too.
Old Jun 22, 2010 | 08:49 AM
impy's Avatar
impy
Backup camera, emblem
There's also the camera that mounts within the emblem, http://www.f150online.com/forums/200...ra-emblem.html
Old Jun 22, 2010 | 09:03 AM
hotnanas's Avatar
hotnanas
did you have to tap into your reverse wiring to auto trigger it when on? if so, which wire? reverse light? in the dash board? ...
reason i ask is, once I order a cam, I will need to do that with my kenwood head unit.
Old Jun 22, 2010 | 09:39 AM
scottzj's Avatar
scottzj
Hangin 10 bra
I did the install of the el cheapo chinese deal, just for trailer hook up, so didnt need anything special. However, it turns out, its actually works pretty darn good.
Old Jun 22, 2010 | 10:43 AM
DIXIEDOG1's Avatar
DIXIEDOG1
Where does the display for the cheapo Chinese deal go?
Old Jun 22, 2010 | 10:56 AM
scottzj's Avatar
scottzj
Hangin 10 bra
Well I bought a 7" LCD Nav/DVD touch radio that has the backup camera system capability.
Old Jun 22, 2010 | 02:14 PM
hotnanas's Avatar
hotnanas
does the cam show when you put it in reverse? or when you goto the option on your head unit?
my head unit has an option to automatically goto reverse cam when I place it in reverse, but I just need to figure out if there's a more convenient place to tap into other than the reverse light.
Old Jun 22, 2010 | 02:25 PM
scottzj's Avatar
scottzj
Hangin 10 bra
Mine comes on when I go into reverse but it also has the ability to be on using the Aux option too.
Old Jun 22, 2010 | 02:31 PM
hotnanas's Avatar
hotnanas
do you know which wire you tapped into to trigger the reverse?
Old Jun 22, 2010 | 04:46 PM
sammy77's Avatar
sammy77
You need to hook up to the hot wire on your reverse light bulb
Old Jun 23, 2010 | 07:28 AM
sdetweil's Avatar
sdetweil
I hooked into the reverse light at the left rear light housing. I then ran a lead from one of my upfitter switches too. This gives backup and manual camera views
When they install my head unit (soon) they will have to tap into the reverse wire under the dash to let the unit know, same thing needed for the mirror
Sam
