c6 transmission
Old Jun 21, 2010 | 12:25 PM
bbussman40's Avatar
bbussman40
c6 transmission
Does anybody know or have a picture of a ford transmission counter weight that ford installed on some transmissions to reduce vibration. I have a harmonic type vibration and we finally figured out it was from the tranny.
This is a 55 f100. c6 9" rear 302 engine
Thanks
Old Jun 21, 2010 | 06:44 PM
85e150's Avatar
85e150
I've seen them on 4 cylinder Pintos--a bar with a bunch of plates riveted together on the end of them. Sometimes found along the side of the road.
With that combo you shouldn't have engine vibes causing issues. Is your drive line lined up correctly? U-joints lined up right? DS balanced? Correct flex plate in the engine?
https://www.ford-trucks.com/forums/8...ance-info.html
Driveline Basics with Steve Johnson - ORN
Output shaft and pinion parallel?
Tom Wood's Custom Drive Shafts - Driveline 101
Trans output shaft bushing in good condition?
http://www.hotrodders.com/forum/c6-t...val-67557.html
Old Jun 21, 2010 | 11:23 PM
85e150's Avatar
85e150
Now I see your earlier post:
c6 problems - Ford Truck Enthusiasts Forums
You fail to mention this amount of slop in this post. Hanging a weight on your trans isn't going to fix this problem.
ox1969
Jun 15, 2015 03:29 PM
lauxg
May 9, 2015 09:39 AM
TestPoint
Mar 9, 2015 07:00 AM
danno75
Apr 12, 2014 01:20 PM
59203shop
Oct 8, 2013 03:21 PM
