drivetrain squeak in right front
Old Jan 7, 2002 | 04:36 PM
tapenick's Avatar
tapenick
I have a squeak in the right front of my 97 Expedition 4x4.
description-
frequency increases with speed
no change with brake
cannot reproduce with wheel off the ground spinning by hand
I seemed to notice that it was louder when under load (accelerating or engine braking) but it may have just been the speed increasing and the load shifting respectively. There shouldn't be any torque xferred to the front in 2H.
Some guys on alt.truck.ford suggested that it might be brake related. I didn't think so because applying the brake didn't impact the squeak. But while inspecting this weekend I noticed the pads were fairly low so I cleaned, greased the caliper slides, and replaced the pads. No change.
Some of these facts point to the wheel bearing... I just have a hard time believing that could be it with only 55k miles. Anyone experienced wheel bearing failure / problems at that mileage?
I guess another possibility is the CV joint. The half shafts turn even in 2H... maybe due to friction in the auto-locking hubs?
Any swags at what might be causing this would be appreciated. Also, if you agree with the wheel bearing or CV joint diagnosis please let me know.
Tom
Old Jan 7, 2002 | 07:44 PM
jonjamky's Avatar
jonjamky
does it squeak when you turn the steering wheel? If it does it ps more than likely the pitman arm.
Old Jan 7, 2002 | 10:17 PM
tapenick's Avatar
tapenick
It still squeaks when turning... but also squeaks just going straight. Forward or reverse.
Old Jan 17, 2002 | 12:00 PM
nottrix's Avatar
nottrix
Definitely the Pitman Arm - mine squeaked and someone in this forum told me to take a syringe and squirt grease right through the boot - hasn't squeaked since!!
Old Jan 17, 2002 | 12:45 PM
tapenick's Avatar
tapenick
Post drivetrain squeak in right front
Ended up being a u-joint. It was one of the front joints on the rear shaft... sort of in the middle of the truck. That's what deceived me into thinking it was coming from the front.
I actually chased the problem in the right rear before running the truck on jackstands to pinpoint the noise.
Tom
Old Jan 17, 2002 | 03:11 PM
wdbatson's Avatar
wdbatson
possom813
Sep 8, 2016 11:10 AM
bigboisteiny
Mar 31, 2015 11:49 PM
mmxchamp
1983 - 2012 Ranger & B-Series
Aug 25, 2014 01:45 PM
SHIP4BRAINS
2009 - 2014 F150
21
Jul 30, 2014 07:14 PM
jim20j
Escape & Escape Hybrid
Jul 17, 2012 03:58 AM
