2011 F150 front end grinding/sqealing
This evening, my F150 with 2,600 miles developed a high pitched squeal, much like you might experience on an older vehicle with failing front brakes. Yes, that same squeal/grind the brakes make...metal on metal. It came in instantly while at highway speeds. It was VERY loud. The pitch didn't really change with speed...it was pretty consistant going slow or fast. There was no vibration, chatter or growl as I would expect with a failing bearing. It was definately in the driveline/brakes. I was 10 miles away from a friends house, so I turned around and took it back to his place. Shortly after turning around, it quieted, only sounding when I would turn ( like a wheel bearing would when being side loaded ). I looked at the brake disks, thinking something was grinding on one of them. The outsides of the disks looked fine. Due to the shields on the inside, I couldn't see.
Later in the evening, I had to drive it back home, about 50 miles. Again, it was quiet unless turning fairly hard. By the time I got home, the squeal had turned into an intermitant growl/thump, as if a warped rotor was banging on the caliper. The noise was 1 to 1 with the rotation of the driveline. But still no vibration. Brakes work perfectly and the noise doesn't change with brake use. Backing up and turning hard results in a variety of sounds, including squeaks.
The hubs and CV joints felt cool. The brake disks were not hot as if they were dragging.
FYI it is 4x4 / 3.7l
I'm going to investigate in the morning. Any clues?
