what are common problems?
Old Jun 20, 2010 | 11:10 PM
projectbad78's Avatar
projectbad78
im looking at getting a small truck, not sure on make but possibly a mid 90s-up ranger.....what are some common problems with them? what kinda mileage they get? thanks
Old Jun 21, 2010 | 11:15 AM
projectbad78
hmmm, 30 views and no replies.........................
Old Jun 21, 2010 | 12:29 PM
powersmoked's Avatar
powersmoked
the mileage vary s from 15 - 26mpg. rear leaf spring hangers and shackles rust. the slave cylinder in the m5od is a weak part and internal. the m5od tranny has rail plugs that fall out and the tranny runs out of fluid
Old Jun 21, 2010 | 02:25 PM
projectbad78
what about the auto trannies? and are explorers basically the same drivetrain?
Old Jun 21, 2010 | 08:33 PM
michigan66's Avatar
michigan66
Rangers and Explorers have the same drive trains. Many owners experience problems with the 4r55e/5r55e automatic transmissions.
See the thread that is currently running for a sampling of what goes on with them.
Old Jun 22, 2010 | 01:48 AM
projectbad78
so all of the autos are either of those 2?
Old Jun 22, 2010 | 04:12 AM
smlford's Avatar
smlford
It may help to give us a little more info on the truck you're looking for...
Do you want he best mileage vehicle (4 cylinder, 2wd)
Do you want the most capable tow vehicle (4.0 L)
Do you want / need 4 WD??
IS an auto tranny or manual your preference??
What do you want to do with it???
Old Jun 22, 2010 | 11:07 AM
projectbad78
well, right now i have a 95 ram that gets around 12 mpgs and im fixin to go back to school which is a 60 round trip.....im just lookin for somethin that is dependable daily driver, decent on gas, and capable of towing my small 14ft aluminum boat.......4wd soesnt matter and niether does transmission
Old Jun 22, 2010 | 11:35 AM
powersmoked
I would look for a 2.3/2.5 4 cylinder. I think they would tow that boat but someone else would knpw that better than me. the I4 are dependable and get good mpg. most of them come with the 5 speed. . but you might find a v6 that is a good deal and those are good also,you can pick these all up cheap espically if you can fix them at all. There is a 93 xcab with a v6 with 109k on it in craiglsit(Boston) for $600 they will take less, it is not getting fuel ,worst case it needs a pump $150. I see something like this about twice a month they are usually around $500. You could spend more and get one that might need any work, but eventually they will all need something.
Old Jun 22, 2010 | 01:03 PM
projectbad78
whats the chances of getting one with a bad tranny?
Old Jun 22, 2010 | 04:35 PM
smlford's Avatar
smlford
It's always a possibility. I believe the 4.0's have the same problematic tranny's as the Explorers. Not sure about the rest of them. But as with any used car try to find out if it was maintained properly and buy the newest / lowest mileage one you can afford.
I would think that a 2.3L four would suit your needs. Mine has been problem free for the 3 years I've owned it.
Old Jun 23, 2010 | 12:33 AM
Paul270's Avatar
Paul270
I bought a used 97 ranger with the 3.0L, 4x4, manual. Its been incredible, most reliable vehicle. I think Ford forgot to put cheap parts in them for future mechanic work. I've had mine over 7 years and besides normal PM all Ive had to do is change the power steering pump and front wheel bearings. The AC has never worked for me, the odometer stopped at 100,000 and the fuel gauge is bad but its taken a beating and a half from me and is still going strong at well over 200,000 miles. It gets 24 mpg on the highway and has plenty of power. I have friends with these pickups too, they've had great experiences with them too. I think they are the best bang for your buck as far as small pickups go.
mban112
32
Jun 13, 2021 08:58 PM
bigtexan99
2011 - 2019 Explorer
Jul 11, 2017 09:48 PM
MoBill122
May 19, 2016 06:02 PM
Damifiknow
Feb 27, 2013 09:44 AM
generaltso64
15
Apr 2, 2010 09:54 PM
