7.3L NO START???
Old Jun 20, 2010 | 10:48 PM
plgebbia's Avatar
plgebbia
7.3L NO START???
This is a early 99 model truck and I know that this is the wrong forum, but I wanted to get you guys input too! ( I already posted in the 99-03 forum) A friend of mine recently bought a non-running 99 Powerstroke that had been sitting for over a year, it was parked because it died on the previous owner and would not restart. I put a new CPS and it fired right up. First problem fixed! Now fresh fuel, fresh oil and filter, and he drives it for two days pulling his trailer with lawn care equipment and it does great, so with no trailer he's driving out of town and he floors it, takes it up to 86-87 mph and backs out of it and it falls on its face, it completely dies and will not restart. So I start checking it over and it has several codes, 0470, 1211, 1212, 0603, and 0340. so I changed the CPS again still no start, and he checked all the fuses, all fine, so I changed the ICP, EBP, and checked the tin nut on the IPR, it was tight. Now we arent getting any codes at all, but it still will not start. It will try to run on ether ( Yes I know ether is a no no) but it is getting frusterating because it has fuel in it and I can here the fuel pump humming but there is no smoke when cranking. And no, the FPR is not plugged, I checked that. Any help is greatly apprieciated! Thanks,
Old Jun 21, 2010 | 01:30 AM
Oversize's Avatar
Oversize
try swapping in a different IDM see if that makes it start and run.
Old Jun 21, 2010 | 07:58 AM
plgebbia's Avatar
plgebbia
Would an IDM out of a 95 model work to check it?
Old Jun 21, 2010 | 08:57 AM
Action4478's Avatar
Action4478
Put the IDM from the 99 in the 95 to test...
Old Jun 21, 2010 | 09:03 AM
Talyn's Avatar
Talyn
I love how the answers are completely different here than in the SD forum. haha.
Old Jun 21, 2010 | 09:50 AM
plgebbia's Avatar
plgebbia
I thought maybe it would be helpful to post in both forums, but now I'm just real confused! HaHa!! Now seriously, one more symptom, when he first got the truck and the cps was bad, when I cranked on the truck for a few seconds, the oil pressure gauge would come up to where it should be while it is running. Now, when I crank on it the gauge jumps around from about halfway up to nothing then back up then nothing and so on, does this describe anything in particular? thanks guys!
Old Jun 21, 2010 | 09:57 AM
chicagodragon's Avatar
chicagodragon
just a shot in the dark, are the batteries fully charged?
Old Jun 21, 2010 | 10:01 AM
plgebbia's Avatar
plgebbia
No, but i was jumping it off his 06 Cummins, maybe thats why it wont start HaHa!!!!
Old Jun 21, 2010 | 10:03 AM
Talyn's Avatar
Talyn
before starting the truck
check the level in the HPOP.
But you cannot really trust that gauge either.
There is a sensor on top of the HPOP, it runs that gauge in the cab your talking about.
Clean it up and make sure its seating good.
And check the HPOP level, it should be within an inch from the top.
being an Early 99, its more of an OBS style truck than a super duty.
But, I'd check the IDM, could have water in it. Trying as rick suggested is a good idea as well.
It really sounds like its getting no fuel though. So, I would check to make sure of that stuff. With no smoke out the tail pipe at all, just sounds like there is a plug up someplace. *shrugs*
Old Jun 21, 2010 | 10:04 AM
Talyn's Avatar
Talyn
Maybe you gave it the plague. haha.
Old Jun 21, 2010 | 10:06 AM
chicagodragon
a man walks into a bar with a set of jumper cables. bartender says "get out of here if you are gonna try and start something"
Old Jun 21, 2010 | 10:08 AM
Action4478's Avatar
Action4478
I was thinking IPR originally , but it is an expensive place to start
Is the Wait to start light still working ?
Try switching the IDM & PCM relays under the hood
Talyn's Avatar
Talyn
priceless.
Old Jun 21, 2010 | 10:32 AM
plgebbia's Avatar
plgebbia
I checked the HPOP reservoir, its full, and it is getting fuel to the filter, but no smoke. Yes, the WTS light is working. Can I potentially hurt my truck by swapping the IDM? Thanks,
Old Jun 21, 2010 | 10:37 AM
Brown Falcon's Avatar
Brown Falcon
It shouldn't hurt your truck to swap the IDM into it. Just won't run the injectors if it's broken.
