Towing w/4.2
Old Feb 6, 2003 | 06:36 PM
mike b's Avatar
mike b
Towing w/4.2
I need to know the tow rating of a 1997 f150 w/4.2v6 and man trans.
Old Feb 6, 2003 | 06:43 PM
johnsdiesel's Avatar
johnsdiesel
Towing w/4.2
Reg Cab 4x2 5800 lbs
Reg Cab 4x4 5400 lbs
Sup Cab 4x2 5600 lbs
Old Feb 6, 2003 | 06:55 PM
mike b's Avatar
mike b
Towing w/4.2
Thanks,those numbers are higher than I thought.I have the chance to buy a 97 s/c w/70k miles on it for $5500.I`m kind of scared of that 4.2 though.Do you guys think I should get a 95-96 with a 300 I6 instead?I will be towing a 4k lb boat 300 miles round trip 2x a month and durability/reliability is a must.
Old Feb 7, 2003 | 09:51 AM
tw's Avatar
tw
Towing w/4.2
If i was gona buy a 6, id buy a I6. Had a 97 with man/v6, it was ok until you put any load on it. I would recomend an I6 with tow package. Very reliable, and lots of low end torque.
Tony Warren
Nebraska
Old Feb 7, 2003 | 09:52 AM
tw's Avatar
tw
Towing w/4.2
My old 77 I6 towed small trailers nicely. I would imagine with fuel injection it just got better
Tony Warren
Nebraska
Old Feb 7, 2003 | 03:15 PM
radar_ridr's Avatar
radar_ridr
Exclamation Towing w/4.2
with manual trans. tow rating is 2000 to 3500 depending on axle ratio.
Old Feb 7, 2003 | 03:45 PM
johnsdiesel
Towing w/4.2
Where did you get your numbers, they don't seem to be correct. Keep in mind this is an F150, not a Ranger.
Old Feb 7, 2003 | 06:52 PM
mike b's Avatar
mike b
Towing w/4.2
Well today I bought a 96 f150 with a 300 I6 and auto trans.The problems with the 4.2 seem to be too many for me.Radars numbers are correct for a manual trans behind a 300 I6 eventhough most people on here tow ALOT more with their man trans.John the numbers you gave above are for an auto trans equipped 4.2. BTW what rear gear is an axle code 18?
Old Feb 7, 2003 | 07:53 PM
johnsdiesel
Towing w/4.2
The 18 is for a 3.08 rear end.
Old Feb 7, 2003 | 08:31 PM
mike b's Avatar
mike b
Towing w/4.2
OK thanks.Think I`ll switch to a 3.55 and I`ll be set.
Diesel_Brad
Nov 7, 2010 08:42 AM
fordtruck87
Engine Swaps
Aug 2, 2006 08:36 PM
jumper1216
Engine Swaps
Feb 12, 2005 03:20 PM
H1RESQ
3.8 & 4.2L V6
Feb 27, 2004 02:22 PM
