Easy Clutch
Old Jun 20, 2010 | 04:56 PM
Derrrrick's Avatar
Derrrrick
Easy Clutch
Hey all, well another possible problem....
This morning when I drove to work everything in my truck seemed normal. The clutch and everything was working fine. Then when I got back into my truck after work I noticed that my clutch was super easy to push. Not so easy that it falls to the floor, but it is a lot easier to push now then it was this morning.
It doesn't feel right, everything else seems to be working OK, it is just I am used to having to use a little effort to push my clutch and I miss it that way.
What would cause this to happen? Is something else going wrong?
By the way, I have a 1992 F-250 with the 351w.
Thanks,
Derrick
Old Jun 21, 2010 | 03:19 AM
gijoe4500's Avatar
gijoe4500
Check your entire clutch hydraulic system to see if you have a leak. Check your master cylinder to see if your low on fluid.
Old Jun 21, 2010 | 03:57 AM
sufferingant's Avatar
sufferingant
x2 on the master.
Old Jun 21, 2010 | 05:10 PM
Derrrrick's Avatar
Derrrrick
So how do I know if it is low on fluid? I opened the cap and there is a little filter in the way, I can't see in it. How full should it be?
Old Jun 21, 2010 | 05:15 PM
gijoe4500's Avatar
gijoe4500
look on the side of the master cylinder reservoir. you should be able to see how much is in there, and a line labeled "max".
94WhiteF250
Oct 27, 2012 09:50 PM
bad_habit59
17
Dec 23, 2007 09:19 AM
Bronco2Nic
Bronco II
18
Apr 5, 2005 06:29 AM
Marky Marc
Dec 2, 2004 09:28 PM
