When using my AE no response from GEM module
Old Jun 19, 2010 | 10:51 PM
robs01f250's Avatar
robs01f250
The reason I hooked the AE up is because my windows, windshield wipers, horn, 4x4 quit working. When the AE is hooked up it states that their is no response from the GEM module. Does this mean that the GEM needs replacing. And if it needs replacing how hard is it to replace? I know the dealer will have to program it to my truck.
Old Jun 20, 2010 | 12:13 AM
Bigcat350's Avatar
Bigcat350
Dang Rob I am not sure what that means but some one one here should. Is the truck still running ok? BUMP for you.
Old Jun 20, 2010 | 11:54 AM
sneak's Avatar
sneak
I've had the same problem with mine, bump for the both of us.
Old Jun 20, 2010 | 12:41 PM
robs01f250's Avatar
robs01f250
yes the truck is running fine. I just dont want to go and buy a GEM module if thats not the problem
Old Jun 20, 2010 | 09:44 PM
Bigcat350's Avatar
Bigcat350
Lets bump again. Some one has had this issue.
Old Jul 23, 2010 | 12:42 AM
robs01f250's Avatar
robs01f250
alright finally got this issue cleared up!!!! Bought the GEM from partsguyed.com last week and finally got to install it today after work!! It took about 1.5 hours because I was taking my time. Replacing the GEM on a truck with an automatic transmission would be alot easier because the clutch wouldnt be in the way. I got it installed and DID NOT have to get it programmed. Everything works as it should!! I called the ford dealership to make sure and they said I didnt have to get it programmed if I bought the gem that was specifically for my truck!!
ScottInTexas
Aug 14, 2013 05:29 PM
Hurricane67
Dec 16, 2011 07:13 AM
dirtmonkey11
Oct 19, 2010 01:54 PM
robs01f250
Jul 26, 2010 11:25 AM
pscrow86
Nov 24, 2009 08:19 AM
