push button start ?????
Old Jun 19, 2010 | 04:45 PM
dmeyer 351 4x4 rebel's Avatar
hey at 2days old i got CP and that weaken my right arm i always started the truck with my left arm but it a pain so like a race car im thinking of a switch or push button start any help
Old Jun 19, 2010 | 04:51 PM
and shift with left arm to
Old Jun 19, 2010 | 08:18 PM
Opossum's Avatar
Opossum
A three position with momentary switch would be real easy to set up, or better yet just get yourself a aftermarket ignition switch with key and put it in the left side of the dash. You would have to remove the safety locks that the stock key operates though.
More info about the truck would be good, year? AT or manual trans, left hand shifting is doable to, but more complicated.
Just looked in your profile it says a 92 F-150, a better but much more complicated solution, not sure how complicated would have to look, would be to just turn the whole stearing column over so everything is reversed. Key would be on the left, shifter on left but go up to put in gear, down to park, and turn signal on right side.
Old Jun 19, 2010 | 11:14 PM
BradyCouchman's Avatar
BradyCouchman
in my truck i use the windshield washer button for the starter. cant tell its there works i like it.
Old Jun 20, 2010 | 09:28 AM
Franklin2's Avatar
Franklin2
A regular aftermarket ignition switch usually does not have enough contacts to work with a OEM setup. Plus you still need to turn the key to unlock the steering wheel.
If you just want a momentary switch to crank it over, you could mount that on the left easily though. You would have to get under the dash and intercept the red/blue wire and put voltage on this. It's what goes through the neutral safety and then to the starter to crank the engine.
Old Jun 20, 2010 | 10:27 AM
its a 92 f150 4x4 351w and the key is broke i use a flat head for a key lol but seeing what the options are before i do anything
Old Jun 20, 2010 | 12:09 PM
Franklin2's Avatar
Franklin2
The mechanical part in the column is broken, but the electrical part of the switch is mounted on top of the column underneath the dash. The easiest way to get to it is to loosen the u-clamp that holds the column to the dash, and drop the column down on the seat. Then you can see the switch. Make sure you take the cover off around the column near the cluster, and disconnect the string that works the PRND2L indicator or you will break it when the column drops
Old Jun 20, 2010 | 02:24 PM
ya but would i be able to get the wires to the ign out to relocate the ignition to another part of the dash (left side)
Old Jun 21, 2010 | 07:51 PM
? would i be able to get the wires out to the left side
Old Jun 22, 2010 | 12:10 AM
Franklin2's Avatar
Franklin2
You are going to have to cut the wires, and splice others in to extend them were you need them.
Old Jun 22, 2010 | 11:20 AM
al right sounds good i all ready have a new ignition would thaT WORK or do i have to get a switch ????????
Old Jun 22, 2010 | 02:08 PM
bashby's Avatar
bashby
Does column from a right side drive truck have the shifter on the left?
Old Jun 23, 2010 | 02:17 PM
not sure what you are saying
cbrd1999
1983 - 2012 Ranger & B-Series
May 30, 2017 04:50 AM
Dhudec
Mar 23, 2017 08:16 PM
Tartersauce53
28
Dec 18, 2016 05:46 PM
brian42
Oct 27, 2016 05:38 PM
mattb77
Oct 21, 2016 12:37 PM
