Isspro EV boost gauge problems
Old Jun 19, 2010 | 09:27 AM
superduty4x4's Avatar
superduty4x4
Looking for some input... put my gauges in a week ago and the boost gauge wasn't working right. It would only read 7 psi max and made a buzzing sound starting around 5 psi. I took everything back apart- no kinks in the boost gauge tubing and all the fittings were tight (and Teflon taped). I took the boost gauge out and jerry rigged it to my compressor set to 30 psi and was able to get the gauge to read 23 psi, which seems okay considering that there wasn't a perfect seal between the compressor and the gauge. Does anyone have any suggestions or input before I put it all back together again?
Old Jun 19, 2010 | 12:53 PM
Hussler's Avatar
Hussler
Maybe make the boost leak detector and check for leaks.
Old Jun 19, 2010 | 01:13 PM
DRRXR's Avatar
DRRXR
I take it that its not a Isspro EV II right.(?) If its direct pressure driven you may try adding a little mineral oil in there and then sleave wrap it where it may be touching something else. Like the fire wall or a line.
Old Jun 19, 2010 | 02:04 PM
superduty4x4
Isspro EV mechanical boost gauge. Had to touch up the paint on the pillar pod, gonna throw it back together after I eat and see what happens.
Old Jun 20, 2010 | 06:48 AM
Talyn's Avatar
Talyn
Yea. he's got a regular EV.
No tubing on the EV2's
Old Jun 20, 2010 | 11:26 AM
superduty4x4
Reinstalled everything yesterday, put the super squeeze to the fittings... gauge still doesn't seem to be working right. No idea what/where the problem is.
Old Jun 20, 2010 | 11:33 AM
DRRXR's Avatar
DRRXR
Diaphragm may be bad. I wonder if the EV II would fit your pod?
Old Jun 20, 2010 | 02:04 PM
Cuda_jim's Avatar
Cuda_jim
Chase, Are you using the plastic tubing or copper?
Did you test the gauge and the tubing together with your compressor?
If you tighten those fittings too tight the plastic tube can get choked off. A copper tube for a mechanical oil pressure gauge will work.
Old Jun 20, 2010 | 02:48 PM
superduty4x4
Using plastic tubing, and no I didn't test the tubing with the gauge, I used some other stuff I had for an ice maker. I'm heading out of town today but I might go out there and try to pressurize the map hose and have my wife watch the gauge and see what happens.
Old Jun 20, 2010 | 02:56 PM
Hussler's Avatar
Hussler
Chase, that's Good idea.
Why didn't I think of that ...
Old Jun 20, 2010 | 03:25 PM
Hussler's Avatar
Hussler
Chase, I did find this. Guy was having buzzing problems around 10 PSI ...
On the Isspro gauges, there is a tiny bleed screw down inside the fitting at the back of the gauge. It winds up working it's way loose. Need a set of those presision screwdrivers for it. I pulled the screw out, a dab of nail polish on the threads, and put it back in. Solved the problem.
Old Jun 20, 2010 | 03:55 PM
superduty4x4
Unplugged the MAP hose from the truck, plugged one end and put the Mityvac on the other end. PSI on the Mityvac gauge wasn't matching PSI on the boost gauge... it was reading about 1/2 of what the Mityvac showed. Looks like a bad gauge head I'd guess, gonna talk to Michael at Isspro to see if he has any suggestions.
Old Dec 10, 2022 | 03:12 PM
yotadieselboy's Avatar
yotadieselboy
1st Gear
Sorry to resurrect the dead thread but I
have the similar problem with my mechanical isspro boost gauge. Not many people have issues with these or not many people buy isspro. It’s quite annoying because i bought isspro after having a egt, oil pressure and temp gauge all mechanical in my truck for over a decade without a single hiccup. This is of course the newest gauge by a long shot and I was showing 10 psi then suddenly went to 2psi. I was thinking my actuator was acting up so I bought a mechanical wastegate actuator adjuster the gauge won’t read now at all. And yes I plumbed it right after the turbo before the controller and wastegate. If I take it off it does seem to work with my air compressor but hard to gauge its accuracy especially in low pressure. I am guessing it’s dinked
Kert0307
Jul 28, 2015 10:08 PM
'94IDITurbo7.3
Mar 26, 2012 07:37 PM
wildstang
Jun 21, 2009 10:11 PM
mxer0022
Dec 17, 2008 04:25 PM
muddrag1
Oct 31, 2008 01:40 PM
