Sponsored by: Real Truck
Which shocks?
Old Feb 6, 2003 | 02:20 PM
basstardo's Avatar
basstardo
Question Which shocks?
It's time to replace my shocks, and I've got it narrowed down between Rancho's and Beilstein's. I've looked at the Rancho RSX, 5000's, and the Bilstein 5100's. I'm looking for something that will give me the nicest ride on the street, as well as be able to take a beating off-road. What do you guys recommend?
On edit: This is stock suspension, no lift.
basstardo
Old Feb 6, 2003 | 02:27 PM
Yeti's Avatar
Yeti
Which shocks?
My opinion go with the Bilstein 5100's , bilstein makes a great shock.
Old Feb 6, 2003 | 02:42 PM
bddo's Avatar
bddo
Which shocks?
I have the Rancho 9000x's....The adjustablility is great...Love'em..
Old Feb 6, 2003 | 02:45 PM
basstardo's Avatar
basstardo
Which shocks?
Hey BDDO, which steering stabilizer did you get? Do you have a Rancho part number?
Old Feb 6, 2003 | 03:02 PM
bddo's Avatar
bddo
Which shocks?
basstardo,
I got the Rancho RS5000's series stabilizer, part #RS5406. I also purchased the bracket kit part #RS5542.
I've read on here that people have put the stabilizer on without using the kit, but that means you have to bend the u-bolts that hold the bracket to get them around the tie rod. Then they have to be bent back to go into the bracket..
The kit was simpler, and it holds the stabilizer better.
If you check out www.eurekaboy.com/f250.htm you will see that he used a different stabilizer #, which is shorter than the recommended, but does fit on to the stock mounts without having to move it.
Either way should work fine.
I've got a pic of it installed if you want it...
Old Feb 6, 2003 | 03:23 PM
johnsdiesel's Avatar
johnsdiesel
Which shocks?
Both are great shocks. I just put Bilsteins on mine and love them.
Old Feb 6, 2003 | 04:08 PM
basstardo's Avatar
basstardo
Which shocks?
Just ordered the RS9000X's. Got a pretty good deal too. I also ordered the steering stabilizer mentioned above. Would have gotten Bilsteins, but I wanted adjustability as well. Thanks for you input guys.
Terry
Old Feb 7, 2003 | 04:28 PM
Ford X Four's Avatar
Ford X Four
Which shocks?
Bro,
you should go with the Bilstein 9100, the ultimate off roading shocks available.
Old Feb 7, 2003 | 04:41 PM
warmdye's Avatar
warmdye
Which shocks?
I like my Rancho RSX's. They treat me right.
