Dropping automatic tranny
Old Jun 18, 2010 | 11:57 PM
750's Avatar
750
The transmission in my truck decided to kick the bucket the other day, so we are pulling it out for a rebuild. Anyhow, we were wondering why after removing the four nuts from the converter through the flex plate why the converter wont slide back into the tranny.
Old Jun 19, 2010 | 12:10 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
if you have separated the transmission and torque converter and spun either or, the pump drive may no longer be aligned. Don't force it!
Why do you need to get them back together if you are dropping the transmission.
-Enjoy
fh : )_~
Old Jun 19, 2010 | 12:13 AM
87crewdually's Avatar
87crewdually
It only has a very little gap until you unbolt the trans from the engine and slide the trans back with the torque converter at the same time. When you drop the tranny the torque converter will come with it.
Old Jun 19, 2010 | 12:19 AM
750's Avatar
750
Alright then. We were going with previous experience with a 460, where the converter slides back about a half an inch or so after pulling the bolts out of the flex plate into the converter. We knew there would be some differences with the 6.9, so i suppose this is one of them. Is there anything else we should be aware of?
Old Jun 19, 2010 | 12:31 AM
87crewdually
You'll notice when you get it out the torque converter will have a drain. It's a 7/16" socket and is located through a hole in the flexplate. I usually mark it with paint for the future ATF interval changes. When you reinstall make sure you KNOW the pump is engaged on the converter hub. This is done by turning it while pushing it in towards the tranny and you'll feel it align. Also pre-fill your torque converter with fresh ATF upon install.
I didn't notice are you turbo charged, if so which system?
Old Jun 19, 2010 | 12:41 AM
750's Avatar
750
No, there is no turbo on it at the moment. Maybe a few months down the road though.
Old Jun 19, 2010 | 07:10 AM
Lazy K's Avatar
Lazy K
Ford C6/NP205 removal and re-installation guide .: Articles This may or may not help.
Old Jun 19, 2010 | 09:46 PM
750's Avatar
750
Thanks for the help guys. We got it out today with some time and a little colorful language. Now, to get it rebuilt and put it back in.
JOHN2001
Jun 11, 2012 05:55 PM
desertPatty
Nov 8, 2010 10:58 AM
blacksheep123
Jan 9, 2007 10:20 PM
mountainman
2004 - 2008 F150
Jun 1, 2004 05:30 PM
trcklvngrl
May 14, 2001 10:29 PM
