Sponsored by: Real Truck
level kit/ snowplow
Old Jun 18, 2010 | 10:03 PM
f250grady's Avatar
f250grady
level kit/ snowplow
I just purchased a 99 f250 super-duty, supercab, 4X4. I am wanting to put a leveling kit on it which looks to be about 2.5 inches and i want to plow with the truck. ( i think it will be a western mvp plus v plow). I do not have the snow plow prep package. I was wondering if anyone has done this and what you may recomend. I would like it not to sag my front end to bad. thanks for any advice or tips
Old Jun 20, 2010 | 07:14 AM
pbeering's Avatar
pbeering
What engine is in the truck? If a 7.3 the MVP may be over the rated weight for the front axle.
In any event I'd install airbags or another leaf spring all the way around.
Be sure to put at least 1000lbs in the bed to balance the truck when plowing.
Old Jun 20, 2010 | 03:39 PM
f250grady's Avatar
f250grady
It is the V 10, other than the springs are thier any differeces in the front axles form the different front axle ratings?
Old Jun 20, 2010 | 05:12 PM
Firefighter 1406's Avatar
Firefighter 1406
You shouldn't have any problems running that plow. Put ballast in the bed like was mention above. And maybe upgrade the springs. I have the same truck but a 7.3 and after plowing two years with my plow I have worn out the springs. I also have a leveling kit. Truck should do you very well for plowing.
Old Jun 20, 2010 | 06:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
level springs don't add weight capacity to your front they are just arched to give you lift. allot of guys here put x-code springs which lift the front about two inches plus they can handle the weight of a plow. if i knew this before hand i would have scraped my front leafs and installed x codes but i put a add aleaf in the front. would have preferred the x codes but o well
Kdr358
Aug 31, 2016 03:52 PM
mykels
2015 - 2020 F150
Nov 18, 2015 02:28 PM
77f2504by4
Oct 28, 2015 09:38 AM
hoss66
Apr 7, 2015 10:28 AM
truckman87
Sep 23, 2011 10:09 AM
