Never bought U-joints before...
Old Jun 18, 2010 | 09:55 PM
RangerHaywood's Avatar
RangerHaywood
So im soon swapping out driveshafts and i figure i might as well throw in some new u joints when comes the time, Bear with me im only 15 but,
1) Do the bearing caps usually come with u-joints or do i have to buy them seperate?
2) Are there heavy duty versions of them for my 78 F-150 w/ single peice rear driveshaft?
3) Are the front u joints the same as the rear u joints?
Old Jun 18, 2010 | 10:02 PM
sniper250's Avatar
sniper250
new u joints always come with new bearing caps
as far as the size difference take a tape measure and check the cap diameter or even a ruler will work
heavy duty u joints are available but will cost more
and if i were u i wouldnt worry with heavy duty ujoints standard factory replacements should work just fine unless u plan on racing or pulling insanely large loads which i would not recommend doing with just a 1/2 ton as far as the pulling is concerned
Old Jun 18, 2010 | 10:12 PM
RangerHaywood
Well i plan to do some pretty hefty off roading with it and i thought they would hold up to the sharper angles better and last longer...?
Old Jun 18, 2010 | 10:25 PM
sniper250's Avatar
sniper250
then i do agree the heavy duty ones are better but they will cost more
Old Jun 19, 2010 | 10:08 AM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
You should always use Spicer universal joints. The "life series" non-greasable are best.
The front joints could be different, AND the rear driveshaft will use different joints on each end.
Old Jun 19, 2010 | 09:38 PM
montana_highboy's Avatar
montana_highboy
X2, though they were bought out by Raybestos they're still genuine Spicer parts.
Old Jun 19, 2010 | 10:35 PM
RangerHaywood
Ok thanks alot guys! I really appreciate it!
Old Jun 19, 2010 | 11:07 PM
HillbillyDeluxe81
Raybestos?? You gotta be kidding me!!
Old Jun 20, 2010 | 01:08 PM
RangerHaywood
Whats wrong with raybestos?
Old Jun 20, 2010 | 01:30 PM
HillbillyDeluxe81
Does this mean I have to start calling my front axle a Raybestos 60??????????
Old Jun 20, 2010 | 03:29 PM
MT-F250's Avatar
MT-F250
X3 I had 200,000 miles on those U-joints on my 95 Ford Ranger. I replaced them even though they were still fine, just to play it safe.
Old Jun 20, 2010 | 06:39 PM
montana_highboy
Sad but true.... Raybestos Brakes - News - Product News Detail
Old Jun 20, 2010 | 11:48 PM
Kalve's Avatar
Kalve
What is so bad bout Raybestos?
slidingdelta
1983 - 2012 Ranger & B-Series
Jun 26, 2010 05:43 PM
SHOpar
Jun 21, 2009 10:32 AM
79pos
1997 - 2003 F150
Jul 8, 2007 11:10 PM
tietje_3
Oct 13, 2006 08:32 PM
guitars2
Nov 5, 2001 09:29 PM
