power windows faulty
Alright no one I've talked to knows the solution to this so I hope someone here does. When I shut my truck of and pull the key out my windows still work no matter what unless of course I unhook the battery. Any ideas?? If it helps the lights inside the buttons work to and I drive a late 1999 f250 psd
And your interior light goes off when you shut the door? All I know is when you open the door, certain cab functions should go dead. That signal obviously isn't getting there.
I'd rather do a head swap on a turbo'd VW Beetle(PITA) than have to screw around with electrical probs. There's some awfully smart people on here, someone will get you pointed straight. Good luck, and let me give you a late welcome to FTE.
https://www.ford-trucks.com/forums/5...jar-light.html
Well right now none of my interior lights work I have to figure that problem out to, I will try that though thank you, just a quick note the tuck has a lot of minor problems but I couldn't pass it up for the price, so I seriously appriciate all the help no I can fix most of it myself I hope
Probably related to the dome light issue (ie the switches on your door latch mechanism). I believe that is the signal to disable the window power. There have been several write ups on how to RR the switch. Hopefully someone has the link and can post it.
so i tried all these ideas and none have any effect, i did discover that my dome lights, cargo lamp, and courtesy lamps are all burnt out so i am guessing if they werent they would stay on 24/7 to. Any more suggestions??
Hmmm I bet Jim would be some help on this one... Since he is an electrician... Perhaps if i yell for him he will show up.....
JIM!!!! HELP!!!!! PLEASE!!!!!
that and he has all the wiring diagrams for these trucks...
You might have a defective switch on the door latch itself. They are not to expensive to buy but are a wee bit of a pita to change out. Steve and Petey changed them out on Peteys truck last fall.
