Intermitent Squeaking noise continues
Old Jun 17, 2010 | 07:01 PM
Explorer Freak's Avatar
Explorer Freak
I have had my Explorer in the shop twice now for the same problems. The 4x4 high/4x4 low lights will flash, and I will hear an intermitent squeaking noise coming from the front of the truck. First time at the shop, the mechanic took off the actuator motor and cleaned the contacts. This solved the problems for about a month. The second time in the shop, he replaced the "shift on the fly" switch on the dash. That worked for about two weeks. Now he's saying it is most likely a $400 module that controls all the electronics inside the vehicle. It controls the gauges, pwr. windows and locks, 4x4 system, radio, ect. We have yet to take it in to have him fix it. The squeaking noise seems to be getting worse. Is the trasfer case locking in intermitently and causing increased wear to the 4x4 components?
Old Jun 17, 2010 | 07:47 PM
caseys's Avatar
caseys
Just a thought... does the front end squeak (with the rig parked in the driveway turned off) and you rock the vehicle back and forth from side to side?
I ask because I had an annoying front end squeak that turn out to be the, I think it was called the front suspension arm bushing... anyway, I can take a picture and show ya. I found this out by crawling under the front and having a friend rock the vehicle side to side. I then drilled a small hole on the top of the arm bushing, inserted a zerc fitting, greased it up... and for the last many years and thousands of miles... no squeaking.
Let me know and I will post a pic...
largefries
2004 - 2008 F150
Nov 11, 2012 12:39 PM
Explorer Freak
May 5, 2010 08:34 PM
Explorer Freak
Apr 15, 2010 09:31 PM
Explorer Freak
Nov 4, 2009 05:33 PM
rbraxton17
Aug 9, 2005 11:06 AM
