Oil sender/Switch conversion
Old Jun 17, 2010 | 05:48 PM
MEDF150's Avatar
MEDF150
I'm thinking of doing the real oil pressure sender mod and eliminate the switch that makes the guage work like an idiot light. What year sending unit do I need? I believe I need an extension to screw it into as well as it is bigger than the switch and won't fit in that location. Where would I get the extension from?
Old Jun 17, 2010 | 06:11 PM
White 97 xlt's Avatar
White 97 xlt
Not sure what years but the part is NAPA Echlin OP-6091... Any "decent" auto [parts should be able to cross that number to their brand..
subford's Avatar
subford
I would say salvage yard for the extension to screw it into from any Ford 302/351 older than say 1986.
You can just tell the auto parts store you need a oil sender for say a 1977 F150.
Do not forget to jump the resister on the back of the cluster.
You may want to watch the video in this Thread:
https://www.ford-trucks.com/forums/9...ure-gauge.html
Old Jun 18, 2010 | 10:54 AM
MEDF150's Avatar
MEDF150
Thanks for the info. The video showed using the 45 degree brass adaptor. That might be easier to find than the extension from a junk yard. I'll look and see if that is the solution. I just changed to a tach cluster so might as well make the oil pressure real too.
Old Jun 18, 2010 | 11:03 AM
jas88's Avatar
jas88
I got my adaptor at the Ford dealer - I asked for one for a 1965 Mustang 289. I used a sending unit for a 1987 Bronco.
Old Nov 1, 2011 | 03:34 PM
300ci Legend's Avatar
300ci Legend
I know this is an older post, but what model would I need to get a sending unit from for my 300 inline?
Old Nov 1, 2011 | 07:42 PM
jas88's Avatar
jas88
1987, like I said. It should be bigger around and taller than the one you take out. It's kinda bell-shaped. It doesn't matter what motor - I took the one out of my 300 Six and screwed it into the 460 I put in it's place - works fine.
Old Nov 1, 2011 | 07:50 PM
White 97 xlt
NAPA part # OP-6091
Any "decent" parts store can change that number to their part #,, if they can't RUN!!!!!!!!
Old Nov 2, 2011 | 06:37 PM
300ci Legend
Originally Posted by White 97 xlt
NAPA part # OP-6091
Much appreciated!
rangerte
1983 - 2012 Ranger & B-Series
31
Sep 30, 2017 01:05 PM
Fixnstuff
Sep 26, 2016 09:56 PM
CB3
Jul 31, 2016 08:33 PM
CharlieLed
Oct 17, 2015 12:24 AM
kirkharrod
32
Jun 26, 2012 01:02 AM
