Ran fine yesterday,,, no start today
04 6.0L
Yesterday when starting the truck it started and died immediately. Figured I just let off the starter to quick, cause it started and ran fine afterwards. I drove to work and at lunch, made a few stops, went home after work, never had a problem. Today I go out to leave and it won't start. Turns over fine, I unplugged the ICP, still no start. I kept it turning over for awhile and got raw fuel out the exhaust, so I quess my FICM is good, and if I'm getting fuel out the exhaust does that mean my filters (I do change them regularly) are good along with the injectors? I've read the "no start" in the tech folder, but would like a most probable place to start. Thanks for the help.
Edit:
My son borrowed a code reader from a parts store. It only showed the ICP code, which went away after plugging the ICP back in.
I have been looking at new trucks and let the fuel run down until the "low fuel" light came on before filling up. This was a couple days ago.
Edit:
on
now on to the op. raw fuel in the exhaust could be a failed ficm, check voltage per tech folder or do a search lots of threads here.
raw fuel in the pipe would mean you more then likly have 500+ psi of icp wich is good.
also check fuel pressure.
any codes?
No codes. I drained the water seperator to see if I had a water problem. Looked good but did have some junk in it so I went ahead and replaced both filters. I get fuel to the upper filter with no problem. I read in the tech folder that if you get a raw fuel smell out the exhaust and no start that it was most likely not the FICM. I'll go back and reread but If this is incorrect please let me know.
on
ya if thats in the tech folder its wrong. I did not right the folder, also as sad as it may be I dont think ive ever looked in it.
if you have ficm issue it can cause the spool valve to hang and dump fuel. so its very possible.
also its a very easy test. there is a cover plate that has to screws holding it on. remove screws you will find four screw under it. do not remove them. you place the red lead on one of the screws and the black to battery negitive. while cranking the engine you should see either 12v or something close to 48v. test all four screws, 2 will be the 12v 2 should be 48v. i just dont remember wich is wich as far as placement.
This is what is in the tech folder under FICM testing procedure
6.0’s, FICM’s and cold-start issues.
If your 6.0 will not start cold, the issue may be injectors, the glow plugs or glow plug controller, or it can be the FICM (Fuel Injection Control Module). If after a long cranking with no start you get a lot of white smoke (raw unburnt fuel) out the exhaust, the problem is probably in the injectors or glow plug system. If you do not get any smoke, the problem is probably in the FICM. It is usually accompanied w/ multiple injector codes and a p0611 code.
I don't have any codes so maybe I read to much into the above statement. I run the FICM test and see what I find.
Thanks for the support.
on
Cheezit you're the man! The FICM tested out at 32v while cranking. Pulled it and followed the resolder instructions in the Tech Folder, reinstalled and it started right up.
I think the info in the tech folder I referenced earlier is misleading,,,, I don't know maybe it's just me, but who should I contact to have them take a look and see if they want to modify it?
insolution
25
03-01-2011 07:21 PM
cobrarep
08-05-2010 07:59 PM
