6.0 won't start
Old Jun 16, 2010 | 11:59 PM
Chuckster380's Avatar
Chuckster380
6.0 won't start
anyone with ideas please
My 05 6.0 won't start it has P2617 fault crank sensor output circuit open, P2614 cam sensor open circuit, do these faults communicate with the oil psi control module and keep it open so oil psi won't build to start engine also checking with my scanner the Injection control Psi showed only 176 psi after cranking engine the psi should at least be 500 I think, can the faults keep the oil psi control module open or is this 3 seperate issues I can't afford to just start replacing parts can anyone help me? thankyou.
Old Jun 17, 2010 | 03:28 AM
bismic's Avatar
bismic
IMO the sensor codes are a result of the no-start.
You seem to have a HPO leak - with a 2005, it is highly likely that it is the STC fitting (HPOP discharge piping).
Old Jun 18, 2010 | 01:25 PM
Chuckster380
won't start
thanks for the reply
do you think the discharge leak would be noticable once I pull the pump manifold off or can I still crankit over to check for leak.
Old Jun 18, 2010 | 04:43 PM
jboczar's Avatar
jboczar
Once you pull the high pressure pump cover you might be able to see the separation where the fittings have blown out but if not just pull the pump and fittings out together and then it should be obvious.
Old Jun 18, 2010 | 07:28 PM
cheezit's Avatar
cheezit
yup. thats what happens.
low icp can be from any number of things. stc fittings, branch tubes, dummy plugs, stand pipes, injetcors, ipr valve.
Old Jun 18, 2010 | 08:13 PM
Chuckster380
won't start
I think before I pull the pump Im going to psi up the oil system for leaks I was told i can make a fitting that fits where the Icp sensor on the right valve cover.
Old Jun 24, 2010 | 11:26 PM
Chuckster380
I found the problem, bad o-rings on the high psi tubes the long ones that bring up the high psi oil to the injector rail, the long tub comes apart and the o-ring inside of the tube was gone (RH) and on (LH) was missing half of the o-ring losing enough oil psi for it not to start after I got it started 20 seconds of cranking I read on a 6.0 bulletin was after starting the engine take it for a ride and work the motor hard between 40 to 50 mph with the turbo pulling hard for about 12 times, I thought it sounded crazy but I did it and then shut off engine and let sit for 5 mins. so I tried it and it started in 2 to 3 seconds. Thanks guys for your help you guys are awesome.
fordpride
15
May 23, 2016 01:00 PM
Icicle
Feb 20, 2016 12:37 AM
ncbondsman
Aug 17, 2015 06:52 PM
farmboy1227
Aug 16, 2015 10:25 AM
Piolet
Feb 18, 2015 06:39 PM
