Black smoke
Old Jun 16, 2010 | 03:01 PM
bigred66's Avatar
bigred66
Black smoke
So my 6.0 throws a small amount of black smoke when I slightly step on the gas. It will only do so for a second or two. From What I have read so far, black smoke out the exhaust seems to be normal when stomping on the pedal or for modded engines.
Is this normal for my situation where I am only slightly accelerating?
Old Jun 16, 2010 | 03:23 PM
jdadamsjr's Avatar
jdadamsjr
Smoke means unburnt fuel...
i.e. unbalanced amount of fuel and air...
either
it is being fed too much fuel for the air going in or
if the fuel is right, it is starving for air...
or something is broke
did u say what mods etc..?
Old Jun 16, 2010 | 10:06 PM
bigred66's Avatar
bigred66
It has no engine mods on it. I just purchased the vehicle and it has just under 40,000miles. The only mod that I'm aware of is a cat back exhaust
Old Jun 16, 2010 | 10:13 PM
bigred66's Avatar
bigred66
Also, the vehicle shows no codes are present when I hooked up my code reader
Old Jun 17, 2010 | 05:55 PM
Young Gun's Avatar
Young Gun
Did you recently have it reflashed?
Old Jun 17, 2010 | 09:32 PM
guthrie&co's Avatar
guthrie&co
I had the same issue. Turned out to be a bad pcm and a coked egr valve. Cleaned and cetane booster along with a new pcm and it runs great
Old Jun 17, 2010 | 09:41 PM
Fallguy2004's Avatar
Fallguy2004
All my diesels have done that. The truck over fuels slightly on acceleration and does not have enough air right then and puffs a little black POOF, but once the truck is able to match the fuel to air miusually within 5-10 seconds) it stops puffing.
I say normal if its just a small puff.
Old Jun 21, 2010 | 05:26 PM
bigred66's Avatar
bigred66
I have not had it reflashed. As a matter of fact, I'm not even sure what that means. Is that like a computer update from Ford or are you speaking of computer tweaking such as an SCT or bullydog?
I did take out the egr valve this weekend and it was pretty dirty. I did some reading and found that carb cleaner works best. It took the crud right off. I bought the new o-ring/gasket kit from ford but managed to re-use the existing parts.
Old Jun 21, 2010 | 05:32 PM
npccpartsman's Avatar
npccpartsman
A flash is a reprogram of the computers. Basically the same thing as using a tuner, but not exactly.
Old Jun 21, 2010 | 06:08 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
pull the egr valve & give it a cleaning, see if that helps.
look in the TECH FOLDER for instructions on cleaning
Old Jun 21, 2010 | 07:35 PM
cheezit's Avatar
cheezit
best place to start.
Old Jun 21, 2010 | 09:28 PM
blowhole's Avatar
blowhole
Couple weeks ago I had the egr valve replaced, had the pcm, ficm, and tcm reflashed to the latest and it smokes on acceleration now. I get more smoke on start up and more smoke when I hit the throttle. Seems to run fine when the air catches up - BUT - it did NOT do this before the flashes and the new egr valve. I also took it to a dealer after the initial work because of the smoke, one that did not do the initial work, and they gave it a clean bill of health after diagnosis and drive testing. Any advice??
I have read on here that some people have noticed that the 6.0's have been a little smokier with the new flash - but that is not a scientific conclusion.
1994F2507.3L
13
Oct 28, 2014 05:11 PM
redsadam
Jul 28, 2013 05:52 PM
phantom 309
Sep 14, 2010 02:14 PM
onuredneck707
Jan 12, 2010 12:47 AM
crescentwrencher
May 7, 2008 10:23 PM
