I have a little 302, and I was wondering if its possable to put a throttle body off a 460 on the 302. I know there isnt a IAC or that coolant passage on the 460 tb, but what else is different? Whats the size difference between the two? I haven't had a chance to look at a 460 tb up close, so I dont know how hard it would be to mod to put a IAC on it or not...
Sorry but, glue as many feathers to it as you want, it ain't gonna fly! Not from a practical standpoint.
I suppose anything's possible, except maybe Obama getting re-elected! Ok, how about "extremely" problematic!
Why would you want to?
Your MAP setup won't deal with it for one thing! Then no IAC?
The 302 & 351 TB are the same not sure about the 460 , its the duel TB right ? You can measure the openings & see , you can put a bigger TB on them BBK makes them , & A bigger MA meter to if its MA ....Lew
Mine is a MAF motor, I was lookin at the BBK units, and for the plans for my 302 the smaller one would be plenty for me. But if I could use a stock 460 tb, and make it work, for less $ and get the same benefits from the bbk, that would be a more cost effective.
Your saying the 460 does not incorporate an IAC? How are you gonna get by that? Transplant the ECU & harness too?
460 IAC isn't on the tb. Its on the upper intake. I'd mod the TB for a IAC if possible. I'd like to find the size difference in the TB themselves to see if it worth the work, or just shell out the $350 for a BBK unit.
Back to problematic. I'm sure other members have more background on this. I'm thinking up a MAF size, but fuel delivery will have to keep up, or you'll lean out. You know, sorry about dismissing your original premise so quickly. There's nothing wrong w/ thinking "outside of the box"!
I fabricated a D/C air booster feeding the airbox when I first got my truck, before I was aware of MAP engine limitations. Actually worked pretty well on the low end, but leaned the engine out farther up the timing curve.
Settled on a K&N drop in, & concentrated on Modding & tweaking the Ignition system (plug gap, base time advance,ect...). basically upgrading/optimizing the basic set up.
A MAF motor is a lot easier to mod than a SD motor. I'm by no means a expert on this subject, but from what I have read, a larger TB will net more power, better mpg and all that. So I figured with a better flowing exhaust, a K&N air filter, TB spacer, EGR eliminater plate and ignition upgrade, a bigger TB would be a good upgrade too. (Don't lol at the mods, I went from 10 mpg to a steady 13.5 mph so far )
I have to go to work now but this is getting interesting. A few things regarding maintaining the air/fuel/spark triad I'd like to kick around. There's other things you can address that will increase performance & MPG at the same time & still keep all the sensors w/ in range. I'll check back later.
Well I've been reading old threads from the early 2000s, and a guy put a 460 TB on his I6, But he never reported back how it worked out for him..... I don't want to shell out $350 If i can get the same gains from a junkyard part for alot cheaper...
There are zero gains to be had with TB changes on the 5.0, matter of fact nothing upstream of intake valves is restrictive until you get a LOT more cam in it and WAY better heads on it.
