another tranny temp question
Old Jun 15, 2010 | 11:32 AM
  #31
Ponyboychris's Avatar
Ponyboychris
Originally Posted by clintusaf
was that included in the price?
I paid a little extra for that above and beyond the tranny. Well worth every penny. I've never seen temps over 170 degrees even on the hottest days in stop and go traffic going up a mountain highway in a construction zone towing my 5th wheel. Yes, it's that cool.
Old Jun 15, 2010 | 01:15 PM
  #32
clintusaf's Avatar
clintusaf
where do you guys get the tru-cool? I'd imagine it's a lot cheaper than the 6.0 cooler.
Old Jun 15, 2010 | 01:39 PM
  #33
SpringerPop's Avatar
SpringerPop
Here's a good place:
http://www.dieselsite.com/index.asp?...ROD&ProdID=205
An $8 option is to order it with OEM-style brackets.
I thought they were a sponsor, but I'm not-so-sure.
Pop
Old Jun 15, 2010 | 02:59 PM
  #34
SpringerPop
If leaving the original, inadequate, oil-to-air (OTA) cooler in place, has anyone worked out the details of bracketry to mount this cooler above the original instead of out in the front?
Pop
Old Jun 15, 2010 | 03:18 PM
  #35
clintusaf's Avatar
clintusaf
Okay. Thanks Springer pop. do i need the one with the cooler bypass valve?
Old Jun 15, 2010 | 03:45 PM
  #36
Neil64's Avatar
Neil64
Trans Rebuild
Prior to having my trans rebuilt February, I was running no higher than 150 degrees in the summer, empty using synthetic ATF. Post rebuild using Dextron/Mercon or whatever the trans shop stuck in there, I am running about 20 (170) degrees hotter than before under similar conditions. This is with the stock cooling system. So can we assume that Mobil 1 Synthetic ATF lowers operating temps by about 20 degrees or is the heat increase due to the new converter, bands, etc.?
Old Jun 16, 2010 | 12:44 AM
  #37
SpringerPop
According to the Tru-Cool instructions, that will be determined by how much below-freezing weather the vehicle will see.
Only you can determine that.
Pop
blams2004
2004 - 2008 F150
20
Aug 29, 2015 03:30 PM
SoCalAngler
Aug 31, 2014 10:38 PM
SoCalAngler
Jul 27, 2014 10:46 AM
geek guy
Jun 6, 2014 08:02 AM
bergy 2000
Feb 7, 2012 02:45 PM
