Truck won't start
Old 06-24-2010, 01:49 PM
Lonnie230's Avatar
Lonnie230
Lonnie230 is offline
Truck won't start
It all started out like it was missing real bad and it got where it didn't want to start the only way I can get it to start is to plug the heater up. Can you give me any idea why it is causing this?
Old 06-24-2010, 01:52 PM
utjer's Avatar
utjer
utjer is offline
First thing to do so we can give any advice is to give us the year of the vehicle, any codes it may be giving, and any other info like that. This will help greatly. Welcome to FTE.
Old 06-24-2010, 01:53 PM
utjer's Avatar
utjer
utjer is offline
https://www.ford-trucks.com/forums/3...ch-folder.html
here is a link to the tech folder. It has tons of info for troubleshooting.
Old 06-24-2010, 01:58 PM
hndacr's Avatar
hndacr
hndacr is offline
If it starts after being plugged in, check the FICM voltage. You can follow the following specification.
https://www.ford-trucks.com/forums/8...procedure.html
Old 06-24-2010, 02:19 PM
Lonnie230's Avatar
Lonnie230
When I plug up my 2004 6.0 it will start right up and runs good do you think it is the FICM? thanks
Old 06-24-2010, 03:10 PM
Lonnie230's Avatar
Lonnie230
Someone???
Old 06-24-2010, 03:25 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,100 Likes on 1,000 Posts
Not to me....sounds more like glow plug problem......
Old 06-24-2010, 05:07 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I'm with Bud on this, at least without knowing more. Get the truck code scanned. It will tell you if you're having glow plug issues. The block heater only warms the coolant and does nothing else as far as electrically aiding the truck. Do you get a long crank time and lots of smoke when it's not plugged in?
Old 06-24-2010, 07:50 PM
Lonnie230's Avatar
Lonnie230
Turns over forever wont start and doesnt smoke but you can plug the heater up for a while and it will start up
