trans oil change walmart super tack
Yes, on several stock transmissions. Works just fine. Just get the stuff that's rated for a Ford trans.
Brian at BTS actually recommends the cheap stuff for a stock trans because the slicker (and higher priced) synthetic stuff is too slick for the stock internals. This could mean premature failure.
I think Brian changed his mind on this because it isn't true. Synthetic ATF is exactly as slick as cheap dino ATF.
I use it. I also use their gear oil in diffs and t-cases in my other older vehicles. But I have no brand loyalty, I buy oil based on specs, not branding.
question
how meany companes really make there brand and how meany just get differnt lables and addtives but it the same stuff after hours peeking around on differnt oils 10w30 , 5w30 for my car & gmc truck alot of them were all made at the same pakagine plant or fac...
i have also heard it like this at the bulk gas station the ( shell or esso or petro can ....ect ) witch were just addtives put in afterwords
could i bee right ?
but i still use shell rot in my work truck
could i bee right ?
could i bee right ?
could i bee right ?
