Sponsored by: Innova
Speaker electrical problem
Old Jun 14, 2010 | 01:36 PM
FarmingFord's Avatar
FarmingFord
Hey everyone
In the past week the driver's side door speaker has stopped working, or so I thought, but if I get next to it I can hear music coming out of it, but it does not turn up with the passenger side speaker. I took the door panel off and checked to see if the connector was loose and put some electrical tape on it but that didnt help. Would a bad ground cause this or do I need to look at new speakers?
BTW my pass. side light is really dim, I dont know if they share a common ground, just thought I'd throw that out there.
Thanks
Drew
Old Jun 14, 2010 | 07:00 PM
ReAX's Avatar
ReAX
Hopefully, the speaker's "ground" returns back to the radio. I'm assuming you're working on the 00 F250 in you sig, so it should. Both wires from the speaker go back to the radio, it makes a bit of difference in how they sound.
Since it's making noises, just not as loud as it should, I'd suspect a high resistance somewhere in the wiring. I'd pull the connector at the speaker and at the kick panel and hose them down with contact cleaner. Then I would look for burn marks on the wires I could find. If you have corrosion on the connectors, it will impede the flow of voltage (I think it's voltage any way), and would not convert back to enough watts in the speaker to produce as much sound as the other speaker. The same would go if you have a short creating a high impedance.
Old Jun 14, 2010 | 09:09 PM
FarmingFord
Yes it is the 2000 in my sig, thanks I will definetely do what you mentioned, I'm kinda dumb in the electrical department (especially sound systems) so thanks for bearing with me. haha
makthenif
Mar 22, 2014 03:00 PM
dualwheels66
Dec 28, 2011 09:09 PM
captandy
Nov 27, 2009 11:01 AM
Woody1255
Jul 29, 2008 04:32 AM
