Here's the speaker size and wiring info for your vehicle. As far as the specs I don't know. If you have a stock system and are just needing to replace the speaker I would just suggest buying a pair of Pioneer 6x8's and just replace both front ones. The Pioneers are a much better speaker and sound better than the stock ones and work just fine. That's what I did in my old 99 Expedition and in my 2012 F-250. Pioneer makes 3 different 6x8's it just depends on how much you want to spend. You can find these at a lot of different locations from Best Buy to Walmart. Just click on the following link, select 6x8 in refine your search, and you'll see what they offer.
Constant 12V+ Light Green/Pink
Switched 12V+ Black/Purple
Ground Black
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Light Blue/White
Left Front (-) Orange/Light Green
Right Front (+) Dark Green
Right Front (-) White/Light Green
Rear Speakers 6" x 8" Rear Door
Left Rear (+) Tan/Yellow
Left Rear (-) Gray/Light Blue
Right Rear (+) Brown/Pink
Right Rear (-) Orange/Red
