1978 - 1996 Big Bronco
1991 bronco transfer case
Old Jun 14, 2010 | 06:08 AM
pungo55's Avatar
pungo55
Talking 1991 bronco transfer case
i recently purchased this bronco and i need to change the transfer case oil, but the fill and drain plugs wont come out, can they be heated. any suggestions.
also it shifts from 2h to 4h but won't shift into neutral or 4L.
Old Jun 14, 2010 | 07:19 AM
g_k50's Avatar
g_k50
shift to 4L while truck is stopped and transmission is in neutral. See if that works.
Try electric impact wrench on fill plugs, case is magnesium so forget the heat, too dangerous.
Old Jun 14, 2010 | 09:07 AM
jas88's Avatar
jas88
I had to drill out one of my plugs, I replace them now with brass plugs from Home Depot and use lots of teflon tape to prevent corrosion between the two dissimilar metals.
clintbonnie
Oct 6, 2014 02:42 PM
jhlowrider
May 13, 2014 07:34 PM
1974F100
13
Dec 12, 2010 11:00 PM
NHBronco
1997 - 2003 F150
Feb 24, 2006 07:40 AM
