o2 sensor simulators
Old Jul 7, 2010 | 08:42 AM
grec-o-face's Avatar
grec-o-face
I've actually made my own 'mil eliminators' in the past. Haven't had a problem --
Here's some reading for you; (scroll down to the bottom) http://http://www.fordmuscle.com/arc...hale/index.php
Old Jan 27, 2011 | 03:09 PM
EricRichards's Avatar
EricRichards
Every one of my last few vehicles all have had oxygen sensor simulators. I typically remove the catalytic converters to improve my gas mileage. You can only install the simulators to replace the rear oxygen sensors. You cannot use 02 simulators in anyway for the front oxygen sensors as The ECM uses the sensors to adjust your engine's Air/Fuel ratio. Contrary to what some people might say the ECM only will throw a CEL for the rear 02 sensor if the voltage is to high or to low , if it dwell time between low and high is to long or short , and if the 02 heater circuit is open, too many amps or to little amps. I know this because I've hand built the 02 simulators used on my vehicles. It really isn't the rocket since that some people make it out to be. In the future you may say look up tables to check between the rear and front 02 sensor data but do you really think companies that will not even use bolts where they can get away with it are going to splurged on ECU memory and programing, I think not...
Old May 14, 2019 | 12:41 PM
Fseriesnexpedition's Avatar
Fseriesnexpedition
Simulators
Originally Posted by ford5.8
I have a o2 simulator on my F150 and it has been working the last 4 years for me.
Do u remember where you got them from and was it for the 5.4l thanks
Old May 15, 2019 | 10:00 PM
V10man's Avatar
V10man
Originally Posted by ACFX4
I have no inspections or exhaust laws of any kind where i live.
You live on the moon?? Removing emissions devices is a FEDERAL law. Just because you don't have testing doesn't make it legal.
Old May 15, 2019 | 10:08 PM
ford5.8's Avatar
ford5.8
The ones I have they don't make anymore. You can buy o2 Simulators on eBay though, they basically just pull the sensor out of the direct gas path giving it a good reading. You can also just put a resistor into the plug in if you know what one you need.
Old May 15, 2019 | 10:09 PM
ford5.8's Avatar
ford5.8
You just quoted a 9 year old post, do you live on the moon?
Old Jul 4, 2019 | 06:30 AM
Jorge Sardina's Avatar
Jorge Sardina
Where can I purchase these simulators, and will simulators work on my F150 XL with a 4.6 v-8?
Old Jul 14, 2020 | 07:18 PM
chris staehle's Avatar
chris staehle
What 02 simulator did you use?
I have a 09 f150 I gutted my cats I bought spacer which didn't work do you have any advice that would work to trick the computer?
Old Jul 15, 2020 | 10:03 AM
ford5.8's Avatar
ford5.8
There is a bypass kit on ebay that is a inline resister that should work. Make sure you are resetting the check engine light when testing these out.
Old Mar 19, 2021 | 11:23 PM
AVTECH24ECOBEAST's Avatar
AVTECH24ECOBEAST
2011 F150 Ecoboost O2 sims.
Would you mind sending me some instructions and parts on how to accomplish this for a 2011 F150 3.5l ecoboost? Looking to perform this option on my truck and by myself, just unaware of the procedure and hardware I my need. Thank you in advance!
rock2610d
Modular V10 (6.8l)
Sep 30, 2020 10:40 AM
Trevor Patrick
Mar 19, 2019 01:20 PM
lupin398
Mar 19, 2011 09:03 PM
jimbob21rc
20
Jul 8, 2005 12:31 PM
wezol5484
1997 - 2003 F150
Oct 31, 2004 06:12 PM
