Tach wiring question
Old Jun 13, 2010 | 12:31 PM
Redcat Diesel's Avatar
Redcat Diesel
I'd like to install an aftermarket tach in my 96 F150. My question is where can I pick up the rpm signal? Truck has a 300 in it. Thanks.
Old Jun 13, 2010 | 12:49 PM
Slip ford man's Avatar
Slip ford man
Check out these diagrams...good luck
Tachometer Installation Autogage Tach Install
Old Jun 13, 2010 | 12:59 PM
lew52's Avatar
lew52
Neg side of coil...Lew
Old Jun 14, 2010 | 03:22 AM
TexasGuy001's Avatar
TexasGuy001
Why not just do a cluster swap for one with a factory tach?
Yeah Lew is right hook up to the negative side of the coil.
It should be wired up like that link says.
Old Jun 14, 2010 | 04:09 AM
Redcat Diesel
Thought about the cluster swap but haven't been able to locate one. I do though have a couple of aftermarket tachs.
Old Jun 14, 2010 | 06:21 AM
TexasGuy001
Thats cool. A great place to mount one, if its a smaller one, is on the steering column cover opposite of the shifter.
Old Jun 14, 2010 | 12:00 PM
Redcat Diesel
That's where it's going. It partly blocks the temp gauge but only the low side.
Old Jun 16, 2010 | 03:14 AM
TexasGuy001
Cool! Were you able to get it hooked up yet? Pic?
Old Jun 16, 2010 | 11:46 AM
Redcat Diesel
I'll prolly get it mounted this weekend. I have to replace the shift lever ( **** broke off ) and rewire the cargo light to seperate switch so I'm planning to do all 3 at the same time.
eagle275
Jun 19, 2015 10:31 AM
rowdyredneck
Aug 3, 2013 10:45 AM
scottscott
Apr 22, 2010 04:08 PM
SouthPCraz
1978 - 1996 Big Bronco
May 31, 2003 12:22 PM
pcman
Feb 16, 2002 07:20 PM
