Header Question
Old Jun 13, 2010 | 09:57 AM
75f100MINE's Avatar
75f100MINE
Header Question
I just removed my passenger header and found it in two pieces. I removed the drivers side and it is one unit. Is this something someone did to get the header into place, or is this the way it was design. I also notices that there was two gaskets on each header. Is this a sign of warped? I will update my subscription so as I may send a picture with this. Thank you
Old Jun 13, 2010 | 04:28 PM
silencebe4thestorm's Avatar
silencebe4thestorm
Sounds to me like someone may have modified it to make it fit. If possible you got any pics? Ya got me a lil interested to see whats goin on there.
Old Jun 13, 2010 | 05:16 PM
DansBBF250's Avatar
DansBBF250
It's pretty common for aftermarket headers to warp... The doubled up gaskets where most likely put in by the privious owner because they where warped ... When you double up the gaskets it fills in the high spots... It's a cheap way of fixing a leak, I would replace the headers and do it right.. Make sure when you are tightening the header bolts, you tighten them little by little untill they are all snug then tourque them down in the normal tightening sequence to prevent warping
stoodley
Jan 7, 2011 02:54 AM
Brad Brown
Jan 4, 2007 04:20 PM
Levergun
25
May 18, 2004 06:50 PM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
HardFordCore
Aug 15, 2003 11:02 PM
