Tranny switch
Old Feb 5, 2003 | 04:06 PM
83F-250OWNER's Avatar
83F-250OWNER
Tranny switch
Is it possible to change my 4 speed man to a 5 speed man, if so is it a real pain or expensive.
Old Feb 5, 2003 | 05:39 PM
HotWhlz85's Avatar
HotWhlz85
Tranny switch
Hey 83F and welcome to FTE.
Can you give us a few more particulars? What kinda engine is it hooked to now?
Old Feb 5, 2003 | 08:58 PM
83F-250OWNER
Tranny switch
Sorry 460 The truck has 40K orig miles. Mint cond.
Old Feb 5, 2003 | 10:17 PM
Ford_Six's Avatar
Ford_Six
Tranny switch
Yes, it is possible, and you can use a ZF 5-speed with no bellhousing mods, as the big block housing had an external slave cylinder. Look for a 92-96 F-250 with a 460 or 7.3l diesel and a 5-speed, and you've found your tranny.
Old Feb 5, 2003 | 10:56 PM
steve83's Avatar
steve83
Tranny switch
...and yes, it's expensive. $800-1300 used; even more for a reman ZF. What can you do? It's a popular transmission!
Old Feb 8, 2003 | 05:21 PM
83F-250OWNER
Tranny switch
Is it going to require any mods, what about the drive shaft.
Old Feb 9, 2003 | 12:18 PM
steve83's Avatar
steve83
Tranny switch
D'shafts, crossmember, trans mount, floorpan adapter, t-case shift lever, backup light switch connector, probably a couple of others...
