code p0683
Old Jun 12, 2010 | 10:43 PM
justindbell's Avatar
justindbell
code p0683
I have the code p0683 on my 2000 ford 7.3.. I replaced all my glow plus today, and reset it. Yet it still comes up and says it is the GPCM. The truck runs perfect, all though the light comes up and needs to be off for smogging in california. What could it be?
Old Jun 12, 2010 | 10:56 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Hi justin and welcome to FTE bro. Could be your Glow plug relay m8. Does it blow blue smoke on start up ??
Old Jun 12, 2010 | 11:12 PM
justindbell
How would you check and determine if it is that? And no it doesn't blow blue smoke. And thank you for the welcome!
Old Jun 13, 2010 | 12:11 AM
ChunderDownUnder
Have a read of this
How to Diagnose the Ford Glow Plug
or this
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Jun 13, 2010 | 12:19 AM
Ponyboychris's Avatar
Ponyboychris
Welcome to FTE. The California trucks and Ex's don't have a glow plug relay (GPR) but a Glow Plug Control Module (GPCM) so something is still not right and it's throwing a code. Most of us have the GPR style system. It's a little late tonight but hopefully someone with a similar setup will chime in soon.
Old Jun 13, 2010 | 12:45 AM
justindbell
ChunderDownUnder: Thank you for your response! I looked at the two sites. Regarding the second one, does my truck have a Glow Plug Relay? Can someone clarify that for me. Also can some explain the whole glow plug computer system, what parts are there to pick from, what are the symptoms, etc? My truck works perfect as I said before. It apparently had one glow plug out.. #6.. although it now has 8 new ones.
Ponyboychris: Thank you as well. I went to Kragen/O’Reileys today, that they guys there didn’t know what was up and said they had no idea what I was talking about. So I told them I thought it was the GPCM, after 20 mintues of not finding that they said the only thing they had was a glow plug relay , and a solenoid as well. After hearing they don’t even have them in California trucks, what’s up with that! I am almost certain it is the GPCM, so I read on a post just recently to check the pigtails on wiring harness to make sure it’s not the problem first, than replace the GPCM. How hard is it to replace those to find out? Is it beneficial?
Thank you FTE members!!
Old Jun 13, 2010 | 09:12 AM
Ponyboychris
You are welcome, like I said, I'm not too familiar with the GPCM system. Unless you run into an employee at a chain auto store that is an owner of a PSD, they usually don't have a clue about our engine package. They might want to sell you a set of spark plugs for Pete's sake...
Here's a picture of the GPCM: https://www.ford-trucks.com/forums/894608-gpcm.html
The GPCM is marked "or this one" in the photo. The relay in front (marked "this one") in the photo is the Air Intake Heater (AIH) Relay and does not effect your condition.
Old Jun 13, 2010 | 05:14 PM
gramicko's Avatar
gramicko
I had the same code for about a year, got a new GCPM and problem was resolved. Just to make sure I would ohm the 9 pin connectors first.
Old Jun 15, 2010 | 12:32 AM
justindbell
But if it was the GPCM wouldn't the truck not work? What exactly does that do?
Old Jun 15, 2010 | 07:07 AM
Ponyboychris
Your truck will start or start rough with the GPCM not functioning right. All it does is activate the glowplugs to heat the cylinders in order to start the truck. It can start without the glowplugs all working, just run rough until the heat builds up in the cylinders to smooth out the idle. I had a bad relay on my truck and it still would start but idled like crap for a couple minutes. The nice thing about the GPCM over the relay is that it will set a code and light up the SES light on the dash. Relays won't set off the SES light.
Old Jun 15, 2010 | 10:42 AM
justindbell
The truck had a glow plug that was out. It told me, which is the job of the GPCM. Would it still be able to read if it wasn't working? Also it starts perfect. Also it can't be the relay since it idles good. Pretty much it drives like a new truck, just it has the SES light on with that code. I've heard a few people say it could be the wiring harnest as well. Is this possible? How hard is this to test?
Old Jun 26, 2010 | 11:55 AM
justindbell
For those of you that throw the same code. I found out after swapping a friend of mines GPCM with mine, that his after sitting for an hour was really hot. And mine that I just turned off was cold. Meaning it wasn't working. I know it's not much of a "mechanic's test".. but it works, and it will save you alot of time. I wish I knew that prior to everything!
Roody727
Jun 20, 2017 06:59 AM
Corndwg01
Nov 2, 2016 09:12 PM
rusbukt
Aug 30, 2014 10:41 PM
andysam
Jan 10, 2014 08:22 PM
himmy14
Jun 5, 2012 06:37 AM
