99 f350 install ignition switch
on
Basic R&R.
From the Ford manual:
Ignition Switch Removal and Installation
Disconnect the battery ground cable.
CAUTION: Use care when removing the instrument panel steering column cover (04459) or damage to the cover locating tab may occur.
On F-250 - F-550 vehicles, remove the instrument panel steering column cover.
Unlock the retainers.
Remove the instrument panel steering column cover.
If equipped, remove the tilt wheel handle.
Remove the lower steering column shroud.
Remove the screws.
Disconnect the ignition switch electrical connector.
Remove the electrical connector bolt.
Disconnect the electrical connector.
Remove the ignition switch.
Remove the screws.
To install, reverse the removal procedure.
Remove the screws.
Remove the screws.
DGMFORD
03-22-2022 12:30 PM
Khauler
13
01-31-2011 10:28 PM
alex crease
09-19-2004 11:52 PM
1999, 99, f350, ford, ignition, installation, installing, instrument, panel, procedures, removal, removing, switch, truck, van
