tires and wheels
Old Feb 5, 2003 | 03:37 PM
PRyan1983's Avatar
PRyan1983
tires and wheels
i want to put some mickey thompson classic 2 wheels on my 72 f100. will my p235/75/r15 sized tires fit on 15x8 inch wheels?
Old Feb 5, 2003 | 04:00 PM
BB's Avatar
BB
tires and wheels
That size tire is approved for a 6" - 8" rim, at least that's what the tire charts say.
Barry
Old Feb 5, 2003 | 05:53 PM
chadburns's Avatar
chadburns
tires and wheels
Hey Barry, is that chart available on the web anywhere? I would like to see what tires fit what rims, myself. Thanks
Chad Burns
1968 F-250 390 2v auto
Aurora, CO.
Old Feb 5, 2003 | 06:08 PM
BB's Avatar
BB
tires and wheels
Hi Chad, I got charts from the Tire Rack a few years ago. Looks like their web site has changed but I’m sure there are more out there if you do a search. As an example, here’s one from Yokohama:
http://www.yokohamatire.com/utrimwidth.asp
Old Feb 22, 2003 | 08:16 AM
cseay1's Avatar
cseay1
tires and wheels
235s will fit on 8 inch rims but the beads will stick out wider than the tread and it will look really funny (picture the sidewall curving outwards from the tread to the edges of the rim, but instead of curving back towards the rim (a convex curve) and being the same width as the tread, the curve continues outward and never curves back in.
the 235 in the tire size it the cross section of the tire measured at its widest part when mounted on its respective nominal rim (which is 5.5-6.0 inches nominal) measured in millimeters. while in this respect the cross section of 235 mm is equivalent to approx. 9 1/4 inches, keep in mind that a) this is cross section and not tread width and b) this measurement goes out the window when the tire is mounted on a larger than nominal rim.
So "will it fit?" . .. yes. Will it look good and handle well?, at least in my opinion "no".
chris seay
bealeton va
49 F1s
68 F100
ozark1
Ford Truck Parts for Sale
Jan 17, 2017 08:23 AM
Excurvelle
All Things Towing
16
Jan 13, 2017 03:54 PM
Badass56
24
Jan 6, 2017 11:14 AM
GeeeMCeee
16
Mar 2, 2014 05:43 PM
Customcab
Jan 4, 2010 03:45 PM
