EGR delete ?
Old Jun 12, 2010 | 03:37 PM
93_flareside's Avatar
93_flareside
Question EGR delete ?
To start, I would like to delete my egr system.
1993, F-150, Flareside, extedend cab, 393 stroker (not fired yet), Edelbrock 3881 intake, E40D w/ jet performance trans adapter, powder coated BW-1356, 4.10 e-lockers fore and rear, 2" leveling springs fore, add-a-leaf rear (2"), 32x11.50x15 BFG a/ts at the corners.
Truck is mainly to pull the boat to the lake, take camping and hiking into the mountains. Not a daily driver.
I have found disagreeing arguements about deleting the egr system- mpgs, power, looks and so on. My reasoning is looks. Lots of money and LOTS AND LOTS of time went into this new motor, and I want to show off my work. That and I live in AZ where it gets to 120 in the shade... Imagine what under the hood temps reach! Expensive plastic lines have been replaced on a bi-yearly basis, by necessity.
I would like to know the best way to go about deleting everything! TAD, TAB, and Canister solenoids. As well as the EGR tube, sensor and valve. I would also like everyon's opinion about it, good bad indifferent or other. I have done quite a bit of research, and found that everyone refers to RJM injection. They don't make a 5.8 setup, but I as$-u-me that the 5.0 kit will work. How and where would the resistors get connected into harness?
Thanks in advance-
Flareside
Old Jun 12, 2010 | 05:38 PM
Conanski's Avatar
Conanski
I hope you're not thinking you can run a 393 on the stock SD computer... you need a tuneable MAF EEC for that. Once you have that capability the whole thermactor system can simply be switched off in the software and the hardware removed.
fishforlife2007
18
Feb 15, 2015 02:31 PM
daddykitty
Jan 20, 2013 01:08 AM
5X5
Oct 22, 2012 08:20 AM
Eightyfive Flareside
16
Jun 10, 2012 10:43 PM
usmcdaveII
Apr 24, 2010 01:57 PM
