LEAF SPRING HANGER
Old Jun 12, 2010 | 03:02 PM
jrandjen4ever's Avatar
jrandjen4ever
LEAF SPRING HANGER
I have a 94 F 150 getting ready to replace the spring hanger after getting it off what is the best way to install the new and then how to i get the leaf spring back into place??
it is the hanger just in front of the rear tire drivers side
harlesshauling@hotmail.com thanks!!
Old Jun 12, 2010 | 03:09 PM
neversosure's Avatar
neversosure
Jack it up and support the frame with stands. Put floor jack under the rear enough to support the rear housing then remove the leaf spring bolt and move the leaf just enough either up or down to get it out of the way so you can get at the hanger. Then (grind, chisel, saw, chew, burn, twist, etc...) rivets out of the old hanger. Install new hanger with good hardware and re-install the leaf spring! EZ 123!
Old Jun 12, 2010 | 03:11 PM
neversosure
PS- leaf spring will not move out of place too much, it will line right back up when you go to re-install it! Good luck!
Old Jun 12, 2010 | 05:53 PM
jrandjen4ever
thank you for the response
waylen89
Aug 10, 2016 10:23 PM
DougJ_1997PSD
May 18, 2016 06:11 PM
'78F250351m
Feb 28, 2013 06:45 AM
Plain Jane
Dec 16, 2011 09:42 AM
andyj ford driver
18
Oct 1, 2011 01:03 PM
