Magnaflow exhaust systems on the 2011's
If you decide to do that, it would be in your best interest to verify you won't void your warranty and that your local shop knows how to get around all of the electronics involved in the exhaust system which is all computer controlled.
Not to mention the DEF system that the 08-10 MY's didn't have.
In other words, you'll have to trick the computer.
Mine is staying stock so I don't really know what I'm talking about but simply providing a warning about the complications you will run into when these have only been in public production for a few months.
Im not going to be removing the DEF or DPF. Basicly its a oversized catback system. except when it comes to our truck it goes behind the dpf and def.
The place thats doing it works on semis and everything so id immagine they have dealt with a DEF system before at some point.
They say its been tested at 29hp and 49tq addition by making it a full 5inch exhaust behind the emissions and replacing the muffler with a high flow
I like quiet which is why im going with the magnaflow. Mainly working for a little more performance and if i get more fuel economy thats great too. I know i could get more power out of a higher flow muffler setup but I dont wanna attract cops like ive seen some big trucks around that can.
The loudest kit i ever had from magnaflow was a 3inch dual exit exhaust for my sky turbo. Was pretty quiet normaly (about the same as a f150 stock) But when you would mash it it would scream.
That car full throttle noise wasnt nothing tho because it had a wastegate that at full throttle u could hear over the exhaust.
They had a big lawsuit years ago about that kinda stuff. Replacing a muffler with a aftermarket as long as its legal in your state they cannot void your warranty. Same thing goes for replacing the pipes. Its all normal maintance items that with age, or road salt up north, just happens.
SVE Q-187.
https://www.fleet.ford.com/truckbbas...ifications.pdf
I would be extremely surprised if you saw any performance increase from installing a def/dpf/cat back exhaust. I've changed out entire systems without dpf and cat and there is no power gain. However, you can dramatically reduce EGT temps. Diesel exhausts are good for two things... Sound and reducing EGT temps. You have any video clips? I wanna hear this bad boy!
Im still waiting for my local shop to get it in for me. The first shipment from there distrib sold out before my order got in.
What is the advantages to lower EGT? I know in heavy towing on inclines it can go up very high and its bad. Would having it lower help me any without towing?
