another 5.0 question...
Old Jun 12, 2010 | 01:40 AM
Bulldawg1081's Avatar
Bulldawg1081
hey guys its been a while since ive last posted but i have more questions!!..i have an '88 F150 single cab long bed i just bought and it has the 302 with a 5 spd manual with stock 3.55 gears and i first was wondering what heads this '88 has? another question is when its in overdrive with these 3.55's im at 2500 rpm at 70mph and i dont remember the rpm's being that high in a similar truck i had with the same gearing and an automatic at the same speed ,is it all to do with the standard transmission? ive heard conanski tell folks that the 5.0 needs atleast 3.73's but i could only imagine what it would do with the rpm's then at 70mph..i want this truck to be a cruiser aswell as have a little get up and go oh and im also going to go with 275/60r15 tires so that will affect the over all gear ratio with a shorter tire so what do you guys think? stay with the 3.55's or go lower?
Old Jun 12, 2010 | 05:49 AM
lew52's Avatar
lew52
I think the heads will be E 7s , i like the lower gears in a 302 , they like a little more RPM s.....Lew
Old Jun 12, 2010 | 07:14 AM
Old Hickory's Avatar
Old Hickory
My 1996 Explorer with the 5.0, EOD, and 3.73 gears turns almost 2100 RPMs at 60 MPH
and I think about 2500 at 70 MPH with stock P235 tires.
Old Jun 12, 2010 | 10:36 AM
Conanski's Avatar
Conanski
OD ratio with the M5OD is 0.79 so it's not as deep as the automatics. But even given that your truck would need 3.73 gears with stock tires(235/75-15) to produce 2500rpm at 70mph.
Old Jun 12, 2010 | 01:11 PM
Bulldawg1081
you thinks its possible the gearing has been changed? the tires are 235/75 r15 now
Old Jun 12, 2010 | 06:01 PM
Conanski's Avatar
Conanski
Yes it's possible, best way to find out is jack the rear axle off the ground, put it in neutral, and count driveshaft rotations needed to make 1 wheel rotation.
Old Jun 12, 2010 | 07:32 PM
Bulldawg1081
i jacked it up and counted and i got 1.75 revolutions on the driveshaft to 1 full revolution of the tire
Old Jun 13, 2010 | 12:50 AM
g_k50's Avatar
g_k50
1260 rpm at 60 mph.
LOL
Old Jun 13, 2010 | 09:03 AM
Conanski's Avatar
Conanski
Did you jack both tires off the ground? You need to.
Old Jun 13, 2010 | 02:21 PM
Bulldawg1081
no,i just jacked up the passenger side,but i can jack up both sides..let me do that and ill post back
Old Jun 13, 2010 | 03:26 PM
lew52's Avatar
lew52
Yeah you should come up with 3+ turns of the drive shaft...Lew
Old Jun 13, 2010 | 04:44 PM
Conanski's Avatar
Conanski
A common mistake, the reason the number of turns is so low is because of gear multiplication through the differential spider gears.
Old Jun 13, 2010 | 05:57 PM
Old Hickory
Conanski is spot on with one wheel jack up answer. Jack up both when doing the revolution test.
Old Jun 14, 2010 | 02:05 AM
xlt4wd90's Avatar
xlt4wd90
If you just jacked up one side (with an open differential), you can just double the number of drive shaft turns to a single wheel turn to get the ratio. If you say you got 1.75 turns of the shaft to make one turn of the wheel on one side, then your axle ratio is about 3.5, or 3.55 is the specified ratio.
Sometimes you can't jack up both sides of an open differential to count turns; if one side has even slightly more drag than the other, both wheels will not turn the same amount, and it will be very confusing try to count their turns.
You can do this with a working limited slip differential; both sides are soft locked by a clutch pack and pre-load springs on the clutch plates, so they will turn together.
turnkyle
26
Jun 27, 2014 07:20 AM
xc4jokestomper
17
Nov 26, 2010 04:49 AM
94powerstroke
18
Feb 25, 2010 05:00 PM
Milwaukee1979F150
Dec 3, 2009 06:35 AM
obx h2o boy
2004 - 2008 F150
Jan 22, 2004 04:37 PM
