The only thing I have ever worried about my truck is the transmission. I honestly have no reason to be worried but I know how much a new one costs so i was wondering what I could do to keep having to replace it for awhile.
Heres what I have
Early 99
Auto (replaced w/Ford tranny probly 35k miles ago)
138k miles
35 inch tires
Superchip 1705 on extreme
I pull a 7x14 enclosed landscaping trailer.
My question:
What can I do to keep my tranny together for another 100k miles??
Any mods, I would like to complete them myself but I have a good mechanic that can do any work. Thanks in advance.
A BTS or John Wood accumulator valve body would be a good start. If you are so inclined, you could install a TransGo Tugger2 shift kit in the valve bodies youself. A larger trans cooler such as the 6.0 or an add-on like the TruCool would extend the trans life.
Well, I watched all half hour of their video, after taking five minutes or so to download it.
Why, pray-tell, did they drop the solenoid pack, or for that matter, the main valve body?
All they did was change the accumulator springs. They didn't even address the habitually-leaky and sticky line pressure modulator valve plunger and sleeve in the accumulator body!
I guess I could understand it if they decided that something in the pack or main body needed cleaning or something, but nada! They did nothing! Changed a gasket? Huh?
I'm sorry, but this doesn't instill any confidence in Transgo's product line at all for me!
Other than an initial orientation to inside the pan (and for a beginner it'll be worthwhile), there's nothing really there....
I put the John Woods VB in which also come with a Transgo Plate. It made a big difference to the shifts. Firm but not to firm. Its supposed to decrease heat build up during shift due to less slippage. For a couple hundred bucks I think its money well spent.
Pop
There are several steps in the instructions that aren't in the video. One is to drill the solenoid pack if the holes aren't already present. There are some valves replaced in the main VB and can't remember but it seems like I had to drill some holes in the main vb. You do replace the line modulator valve in the accum body as well. Mike and Joe both did great writeups on the transgo install.Transgo Tugger Kit Install by Mike
There are several steps in the instructions that aren't in the video. <snip> Mike and Joe both did great writeups on the transgo install.Transgo Tugger Kit Install by Mike
That would make a lot more sense!
And yes, I had already read Mike's (and Joe's) very comprehensive write-up back when he did it. I guess I just expected to see more of the whole thing, given that it took them a half hour to show what they did.
