I have an 02 f250 7.3 powerstroke and I have the chance to buy a hypertech programmer cheap that says on the box 1999-2000 7.3 powerstroke. Will it fit mine?
Why is it they have it for the same engine just different years. This is the first time I've seen some work on a 2000 that won't on the 02
Probly difference in PCM codes.Just a guess
When my PCM was replaced my programmer wouldn't work any longer and had to send it back to hypertec to be reprogrammed
My truck came with a Hypertech, I'm not impressed. Hoping to upgrade to a DP soon. Once a vehicle is programed with a Hypertech, the Hypertech programmer cannot be used on a different vehicle until the tune is uninstalled from the original vehicle. If you do buy it, make sure the PO has proplery uninstalled the tunes or it will not work.
