Sponsored by: Auxito
replacing pitman arm
Old Jun 11, 2010 | 10:09 AM
JP_McCann's Avatar
JP_McCann
i was wondering how hard this would be on a 4x4 4.6. Will i need air tools to get the steering shaft bolt off? Can a puller get in there to pull the arm off? Any suggestions would be great.
JP
Old Jun 11, 2010 | 05:46 PM
4.6 triton's Avatar
4.6 triton
You need to unbolt the steeringbox off the frame. The puller will not pass without it.
Impact, pitman arm puller, big hammer and theere you go
Old Jun 11, 2010 | 10:56 PM
JP_McCann's Avatar
JP_McCann
how hard is it to remove the steering box from the frame?
Old Jun 13, 2010 | 12:02 AM
Doc's Avatar
Doc
I'm just curious. What is it doing that makes you want to change it? If it's making a really bad squeaking noise, I know what might help.
Old Jun 13, 2010 | 12:04 AM
JP_McCann's Avatar
JP_McCann
My mechanic said that it needed to be replaced when i had him do the 02 sensors. When i looked at it the ball joint boot was all torn apart. I agree that it needs to be done.
Also what size is the bolt that holds the pitman arm to the steering box?
Old Jun 13, 2010 | 12:21 AM
Doc's Avatar
Doc
Oh okay. Yeah that needs to be replaced. I have the same truck, and that boot started making a terrible squeaking sound every single time I turned it at slow speeds like in a parking lot not too long after I bought it. I went to the auto parts and got one of those needles with a grease fitting and injected grease into the boot. Never had another problem. But unfortunately that isn't gonna help you if it's torn apart. But it may help somebody else. Good luck. I imagine that's a pretty big job.
Old Jun 13, 2010 | 11:45 AM
4.6 triton's Avatar
4.6 triton
Very easy job.
You unbolt the 2 front bolt for the steering box, lose enough the last on the back to swivel steering box.
Remove the center link form the idle arm and from thr pitman arm, drop it down.
1h job
Old Jun 13, 2010 | 12:59 PM
JP_McCann's Avatar
JP_McCann
Do you know what size the nuts are?
Old Jun 13, 2010 | 02:34 PM
4.6 triton's Avatar
4.6 triton
1 1/4" for the big nut on my 98. 1 5/16" on my f-250
Old Jun 13, 2010 | 05:44 PM
JP_McCann's Avatar
JP_McCann
anyone have any tips for doing this without an impact wrench?
Old Jun 14, 2010 | 12:42 PM
93 mix 'n match's Avatar
93 mix 'n match
something like this really needs an impact.
Old Jun 14, 2010 | 08:33 PM
TheTinian's Avatar
TheTinian
Breaker Bar, or a long cheater pipe. I never use an impact on them.
Like the others said, remove 2 of the 3 bolts from the box and loosen the other one to get the puller on there. Shouldn't be more than a 25 minute job.....
Old Jun 15, 2010 | 03:18 PM
JP_McCann's Avatar
JP_McCann
what size socket did you use?
Old Jun 15, 2010 | 04:42 PM
TheTinian's Avatar
TheTinian
1 1/4 i think
Old Jun 16, 2010 | 12:20 AM
JP_McCann's Avatar
JP_McCann
when i go to tilt the steering box do i need to do anything to the steering column? I am also assuming that i am using the impact once the steering box is tilted.
jp86150
16
Oct 14, 2020 12:11 PM
jp267
Connecticut Chapter
Aug 10, 2017 08:03 PM
JP_E350
Apr 13, 2016 05:56 PM
CitywideFl
Jun 14, 2015 08:05 AM
JP11283
1983 - 2012 Ranger & B-Series
Aug 2, 2004 03:55 PM
