EOT and Coolant
Old Jun 11, 2010 | 01:37 AM
caere's Avatar
caere
EOT and Coolant
Generally I don't see more than a 15 deg difference in my eot and coolant temp. But if I switch to max a/c the coolant temp drops but eot stay the same. Which creates a 20-23 deg difference. This is while under heavy acceleration or just cruising at 75 mph. Ive read that 15 deg difference is the max I should have. Am I looking at some repairs soon?
I'm thinking I'll get a coolant filter installed. Any recommendations?
Old Jun 11, 2010 | 05:31 AM
npccpartsman's Avatar
npccpartsman
You should already be doing the repair to your oil cooler IMHO
Old Jun 11, 2010 | 07:29 AM
ehgeeray's Avatar
ehgeeray
The coolant filter will save your next oil cooler... this one is toast
Old Jun 11, 2010 | 08:33 AM
69cj's Avatar
69cj
The horse is out of the barn. You can use the saddle on the new horse.
Old Jun 11, 2010 | 09:52 AM
spinge's Avatar
spinge
My question is why does the coolant temperature drop when the AC is on? One would think that if anything temps would go up since more heat is being introduced ahead of the radiator.
Old Jun 11, 2010 | 09:53 AM
m-chan68's Avatar
m-chan68
Fan clutch.
Old Jun 11, 2010 | 10:02 AM
spinge's Avatar
spinge
Originally Posted by m-chan68
Fan clutch.
And the light over my head came on, and it was blinding........otherwise known as "DUH, my bad"
Old Jun 11, 2010 | 10:35 AM
caere's Avatar
caere
Fan clutch? Can you elaborate?
Old Jun 11, 2010 | 10:37 AM
spinge's Avatar
spinge
When you turn the AC on high the fan clutch kicks in (engine cooling fan) and moves more air across the radiator.
Old Jun 11, 2010 | 10:45 AM
caere's Avatar
caere
So should I be concerned that there's a 20-22 deg difference when the a/c is on?
Old Jun 11, 2010 | 10:54 AM
spinge's Avatar
spinge
That would lead me to think that the oil cooler is not working as effectivley as it should, and the oil temperature is not dropping to match the coolant temperature (or staying within the 15 degree range). All points to the oil cooler being (or starting) to clog on the coolant side. Although you mention adding a coolant filter, this does not fix the problem, just prevents it on the next cooler. If the problem is let go too long, then the reduced flow to the EGR cooler will cause it to fail, and can cause ALL sorts of heartache. Is your truck still under warranty? Others will chime in (I am not sure) if this is a proactive repair while under warranty, or if something has to fail to be repaired.
Old Jun 11, 2010 | 11:01 AM
caere's Avatar
caere
No warranty. It's an '04 with 150,000 Miles.
I'm sure they replaced the oil cooler when I had the head gaskets done about 30,000 miles ago. THey go bad that quick?
Old Jun 11, 2010 | 07:24 PM
rickatic's Avatar
rickatic
They will if the silicate dropout and casting sand are not filtered out. Fix the oil cooler and install a coolant filter ans some monitoring equipment.
Old Jun 17, 2010 | 08:18 PM
caere's Avatar
caere
So, I cleaned my EGR valve for the first time. It was a real bear to get loose. But i got it off. THe valve itself didn't seem to bad. The intake did have some oil sludge. So from what I've found searching the forum is that this is probably the oil cooler leaking/failing? SO that may explain the difference in the eot and ect. Funny thing is yesterday while pulling my larger trailer at 70 mph into the wind it was easily under 15 degree difference. But without the trailer on it again fluctuated from 15-22 degrees difference. I think I will do an oil cooler upgrade. Is the bullet proof diesel one good?
If there wasn't a lot of sludge then I'm hoping I'll beat the egr cooler failure. I'm thinking of doing the egr delete or bypass. My Ford tech said they would still be able to do diagnoses and repairs if I modify the truck.
Old Jun 17, 2010 | 10:22 PM
Jayybird's Avatar
Jayybird
While yall on the subject,
Does anyone know what an oilcooler replacement costs? Just curious, I've read a lot on this issue and it seems to be a common problem. The girl has head gaskets, so i assume the oil cooler or injectors will be the next culprit. Not that I have a lack of faith, just one of those things i want to keep an eye on. Also, does the edge insight measure EOTs?
Thanks, input is much appreciated.
2005, FX4, F250, 127k miles
