front lift question
Old Jun 10, 2010 | 11:20 AM
|WYG|SS's Avatar
|WYG|SS
front lift question
i had recently purchesed some 2in coil spring spacers and coil springs which brought my front of my 93 f150 4.9l 4x4 about 3in. what do you guys think about this to help fix my bad camber i had on my wheels when i had put the spacers and springs on?
now i am changing axles in front i would like to do the coil lift agian. can i get this
http://www.jcwhitney.com/alignment-b.../p2004333.jcwx
would it help with the camber problem with the wheels?
and would this possibly be a weak spot when i go offroading?
Old Jun 10, 2010 | 10:30 PM
nighthawk285's Avatar
nighthawk285
Yes those drop brackets do help get everything back close to spec, but you may also need offset ball joint bushings, but with only 3 inches of lift, I doubt it.
As far as a weak spot, these do put a bit more strain on the engine x-member, and I have heard of guys tearing the x-member or the frame, but I don't know how extreme they were going. I have been running mine with 35" tires, 6" drop brackets, and go 'wheelin about every other week (normally) and I have never had any problems.
Old Jun 11, 2010 | 08:23 AM
|WYG|SS's Avatar
|WYG|SS
i do have the adjustable camber bushing also i bought. mayabe i will try these. where i go its nothing major just a buch of puddles with some rocks but i go slow thru them unless i know their is no rocks i just give it.
Old Jun 11, 2010 | 08:30 AM
jas88's Avatar
jas88
I put 2" lift coils on my '91 F150 and I was able to get it back aligned using offset bushings I bought at Advance Auto Parts.
Troy_455
Jul 30, 2015 04:02 AM
Tim Young
1966 - 1977 Early Broncos
Feb 8, 2014 12:52 PM
Beau Bo
Apr 5, 2012 08:36 PM
vervepipes
Feb 7, 2011 08:07 PM
akinswi
2004 - 2008 F150
19
Dec 10, 2010 04:40 PM
