Shutting down when warm
Old Jun 10, 2010 | 07:54 AM
gwolf58's Avatar
gwolf58
My 2002 F350 7.3 4wd AT is shutting down when warm. The engine does not run rough before it dies. The engine will start again once the engine temp returns to cold. The engine starts right up when cold just doesn't restart once it stalls. I have replaced the CMP, fuel filter and the oil pressure switch. The oil pressure switch seemed to fix the problem for 2 days, then yesterday the truck died again. I did not check for codes and there are no warning lights on.
Old Jun 10, 2010 | 07:59 AM
just another truck's Avatar
just another truck
CMP??
I would be leaning towards the CPS. But I am not sure this isnt what you are already saying.
Old Jun 10, 2010 | 08:04 AM
gwolf58's Avatar
gwolf58
My manual abbreviated the camshaft position sensor as cmp. I believe that is the same. Thanks
Old Jun 10, 2010 | 08:26 AM
Ponyboychris's Avatar
Ponyboychris
Welcome to FTE.
Explain a little bit more on what you mean by "cold." Do you have to let the truck sit overnight, a few hours, etc?
Old Jun 10, 2010 | 08:38 AM
gwolf58's Avatar
gwolf58
The temp gauge has to return to the cold position. I just noted from another post to check for oil in the HP oil system pressure sensor connector. It was oily, could that cause this problem?
Old Jun 10, 2010 | 08:54 AM
gwolf58's Avatar
gwolf58
I just fully warmed up the truck (in park) and put it in drive. The truck went about 100 yds and when I let off the throttle the engine died just like it was shut off. Now I'm waiting for it to cool back down to restart to get it off the road.
Old Jun 10, 2010 | 01:27 PM
gwolf58's Avatar
gwolf58
The truck sat for 4 hours, the temp gauge was on cold and started right up and I drove it home. Runs great when cold.
Old Jun 10, 2010 | 01:54 PM
tdpower's Avatar
tdpower
Might be your ipr. I heard of someone putting a bag of ice on it and could get it to start that way.
Old Jun 10, 2010 | 01:59 PM
Pocket's Avatar
Pocket
My truck did the same thing when the IPR was sticking. Would run fine for a while, then die. Couldn't restart the truck for a while until it sat for anywhere from 30 minutes to a few hours, then it would start up and run normal again.
I'm betting IPR for you.
Old Jun 10, 2010 | 03:26 PM
zx250's Avatar
zx250
Of the next Riffraff East
It does sound like your IPR, but if you ICP has oil under the plug, then it is on it's way out as well. Oil come from the ICP having a hole in it. Here's an old pic of mine that will help you with the locations.
Old Jun 11, 2010 | 11:23 AM
gwolf58's Avatar
gwolf58
I have an IPR on order and will let everyone know how it went. Thanks so much for the help.
Old Jun 11, 2010 | 01:43 PM
gwolf58's Avatar
gwolf58
I changed the IPR and brought it to full temp. Still running great. I'll know next week if that was the cause for sure. Thanks for the help and the great diagrams.
Old Jun 11, 2010 | 02:45 PM
zx250's Avatar
zx250
Wow, that was fast, two hours from order to completed install. Glad it seems to have done the trick. You can clean the old one and keep it for and emergency back up. I dont have the link with me on the cleaning procedure, but someone will. Thanks for posting back.
Old Jun 11, 2010 | 03:30 PM
CSIPSD's Avatar
CSIPSD
Keep the old one around, you can clean it and keep it around for a spare...
Old Jun 11, 2010 | 03:49 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I would add get a new o-ring as well since they have a bad habit of leaking when you try and reuse them.
Replacement O-rings for Ford Diesel Engines
