Need help..
Old Jun 9, 2010 | 07:38 PM
6point0's Avatar
6point0
Need help..
Alright. i cant search EVERYTHING in/on this list..
can people share their knowledge?
Twelve best mods (IMO):
1. coolant filter (dieselsite filter is a good choice).
2. Stiffer fuel pressure regulator spring (3c3Z-9t517-ae) or the BB mod.
3. Larger turbo oil drain tube (depending on your year model) (Ford Part # 6C3Z-9T515-A or International Part # 1876071C91)
4. Gauges!!! Especially fuel pressure, boost, ECT, and EOT.
5. ccv re-route ( 1 inch hose, GST-II for oil resistance, and a Racor filter - either a 4500 or a 6000, ).
6. Fumoto valve (http://www.dieselsite.com/index.asp?...PROD&ProdID=33)
7. Updated HFCM drain plug (Ford #6E7Z-9C082-A or International #2589259C91)
8. Harpoon the fuel tank
9. High idle mod
10. Power steering filter (Magnefine #M010CB - w/ 3/8 inch connections).
11. BriteBox
12. 24 inch windshield wipers
I dont know what most of this means....haha
also
Drain your HFCM every oil change and when you drain water from it, empty it into a jar and visually inspect. WHAT!? drain water from it. yeah yeah... but where is it!
Old Jun 9, 2010 | 08:03 PM
texans's Avatar
texans
I don't understand. What is the question? And also I would say a regulated return is better than doing the spring, or the bb mod IMHO.
Old Jun 9, 2010 | 08:08 PM
adamtheman16's Avatar
adamtheman16
Driver's side frame rail, front of cab. Black plastic cap is the filter. Unscrew with a 1 7/16" socket.
Old Jun 9, 2010 | 08:10 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
1. Coolant filter: first mod done on my truck, yes dieselsite.
2. Only if you have checked your fuel pressure to make sure you actually need it. Don't do it until you know. (Thus # 4 Gauges )
5. Keeps oil that comes from CCV out of the intercooler hoses, and help keeps the CAC tube fro blowing off.
6. Easier oil changes.
7.HFCM picture,(see below) under the driver side door in the frame. The brass plug you can barely see. Under the fuel heater harness. Be careful it tends to strip, thus some get : Updated HFCM drain plug (Ford #6E7Z-9C082-A or International #2589259C91)
8. Harpoon the fuel tank: lets you get a couple more gallons of fuel in tank faster. The vent tube sticks into the tank too far
Old Jun 9, 2010 | 08:11 PM
amdriven2liv
9. High idle mod
11. BriteBox
also
Most of this is in the tech folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
and keep this handy:
http://www.backglass.org/duncan/ps60_manual/
Old Jun 9, 2010 | 08:21 PM
texans's Avatar
texans
FYI, you drain the water from the drain on the side of the hfcm. It take a 7 mm allan wrench (iirc). You don't take off the cap.
Old Jun 9, 2010 | 09:17 PM
cheezit's Avatar
cheezit
it a metric truck. its a 36mm.
also if the cluster has a boost gauge its rather accurate so you can opt for something else
Old Jun 10, 2010 | 12:28 AM
adamtheman16
Oops, yeah, forgot to mention that part of it!
Yeah, I have never tried to find the metric "equivalent". I use the SAE socket because that is what I have and it works. No sense in buying a 50 dollar metric socket if the SAE one works just fine. Good tip for those people at home who don't have a full set of large metric sockets, but do have a 3/4 drive Craftsman SAE set laying around. I was thinking to myself when I said that though "what is the metric size of that hex?"
Old Jun 10, 2010 | 10:10 AM
cheezit's Avatar
cheezit
heres the correct tool and it's less then $10.00
AutoZone.com | Oil Filter Wrench | 36 mm. oil filter socket
Old Jun 10, 2010 | 10:22 AM
npccpartsman's Avatar
npccpartsman
I got a craftsman 1/2" drive for $6 back in 04. A little more now but good quality and warranty.
Old Jun 10, 2010 | 10:39 AM
69cj's Avatar
69cj
It's a 6 mm hex
Old Jun 10, 2010 | 12:39 PM
texans's Avatar
texans
Thanks 69CJ I couldn't remeber for sure, but at least I was close.
Old Jun 10, 2010 | 05:49 PM
rocky1074's Avatar
rocky1074
That's the one I use..Works Great For Fuel & Oil filter. I believe the secondary fuel filter is a 24mm socket..Just want to chime in..
Old Jun 10, 2010 | 09:10 PM
6point0's Avatar
6point0
thanks for the info Gents..
But I guess my main question is are they all " you have no choice but to do this if you own a 6.0" type of mods...
Like why do i need a coolant filter as well as the rest of the list....
Follow?
Old Jun 11, 2010 | 09:38 AM
amdriven2liv
Well, you can take 6,8,9,11,12 off the list if you want. Those are things to make things easier for you. Not the motor. Unless you require a lot of idling, then 9 would stay. The rest are good to do. I have done 1,4,5. ( i don't have fuel pressure gauge yet, but will soon)
3 I'll do when I need to be in there for something else.
2 depends on getting the fuel pressure gauge.
7 will come if and when I need to replace the stock one.
wla6518
19
Nov 11, 2014 12:34 PM
Patriotic Rottweiler
Jul 6, 2014 08:21 AM
tjbeggs
40
Feb 8, 2014 10:10 AM
davidkstyler
Dec 22, 2010 12:52 AM
Knotwild
42
Feb 14, 2008 02:49 PM
